H22 Civic hatch?
Old May 18, 2003 | 01:01 AM
TalontedTSi08's Avatar
Default H22 Civic hatch?
Can you put a H22 into a 92 civic hatchback? I hear all that is needed is motor mounts, is there anymore modifications needed to perform this swap?
Thanks for you help in advance,
Daniel
Old May 18, 2003 | 02:09 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: H22 Civic hatch? (TalontedTSi08)
One modification: "search"
Old May 18, 2003 | 02:15 AM
Toda Built's Avatar
go to the hybrid section of h-t.com... pleanty of people have performed the swap and can give you all the details you need
Old May 18, 2003 | 08:51 AM
sappsycho's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TalontedTSi08 &raquo;</TD></TR><TR><TD CLASS="quote">Can you put a H22 into a 92 civic hatchback? I hear all that is needed is motor mounts, is there anymore modifications needed to perform this swap?
Daniel </TD></TR></TABLE>
Here, I'll try to help and not be a dick and just tell you to search.
First off, you'll need the swap, of course. HASport makes some bolt in engine mounts, you'll need them (Other companies make them but it seems that the general consensus uses the HASports.)
Since it's an EG, you won't need to do any banging or anything to make it fit, it should fit fine with the mounts. If you wan't, you can use a Del Sol dual core radiator and it'll give you a bit more room.
And since it seems you're kind of new, I'd say you should probably get some more experienced people helping you or get it done at a shop. Learn more before you just delve in.
Old May 18, 2003 | 11:12 AM
AudioFuct's Avatar
Yes you can. There is a ton of crap your gonna need. This is considered one of the hardest swaps to do, so hopefully you either have experience, or you have some experienced help.
Old May 18, 2003 | 11:19 AM
UpstateCivic's Avatar
Default Re: H22 Civic hatch? (AudioFuct)
All you really need is a search button....
HondaS2000
Sep 22, 2008 07:03 PM
Deacatur Racer
Dec 9, 2007 12:04 PM
jdmkids12
Honda Civic (2001 - 2005)
Nov 27, 2007 08:29 PM
si foo
Jun 27, 2003 03:15 PM
