ls in ek..wont start
Old May 18, 2003 | 08:35 PM
civcexcoupeblack's Avatar
Default ls in ek..wont start
I have my 95 ls motor in my 98 civic. It in, and when we try to start it, it turns over, but its not getting fuel (i dont hear the fuel pump prime). What would cause this, and how do I fix it?
Old May 18, 2003 | 09:08 PM
Rpc07's Avatar
Default Re: ls in ek..wont start (civcexcoupeblack)
bump
Old May 18, 2003 | 09:14 PM
NXLude's Avatar
Id say check the fuse to see if its ok. Then check to see if power is getting to the pump via a multimeter, then if there is power getting to it and no pump action then get a new pump. If no power getting to it, check your wiring......
Old May 19, 2003 | 06:43 AM
Default Re: (NXLude)
fuse is fine.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">Id say check the fuse to see if its ok. Then check to see if power is getting to the pump via a multimeter, then if there is power getting to it and no pump action then get a new pump. If no power getting to it, check your wiring......</TD></TR></TABLE>
Fuse is fine. The pump is in the gas tank, is it not? There is another one in the engine bay, but I see no wiring that should be hooked up to it.
Old May 19, 2003 | 06:03 PM
xSpooNxEkx's Avatar
Default Re: (civcexcoupeblack)
you can have someone start the car and you can listen to it inside your car... just take off the lower piece of the back seat if you ain't good in hearing.... but the fuel pump shouldn't die on you after the swap... is there any fuel leak? like the hose to the fpr or the one connected from the fuel filter to the fuel rail?
Old May 19, 2003 | 11:53 PM
Default Re: (xSpooNxEkx)
there was a ground missing......its up and running
Old May 20, 2003 | 12:43 AM
aLLjDMRalf's Avatar
yep something small can feel like some thing major well good luck with the rest of ur project
Old May 20, 2003 | 06:59 AM
ransack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civcexcoupeblack &raquo;</TD></TR><TR><TD CLASS="quote">there was a ground missing......its up and running
nice. I like it when its just something like that. Like when I started mine, it didnt idle. then I was like duh...no throttle cable. put it on and bam.
boost16awd
Apr 4, 2017 07:31 AM
blaze_125
15
Aug 26, 2008 08:52 PM
SiRay13
Oct 9, 2006 09:58 AM
22boost
May 13, 2006 04:44 AM
hitman602
10
Jul 20, 2005 02:42 AM
