B17A Into EF Civic or CRX
OK I have a 92 GS-R. My car must go down for a while. I want to put my b17 into a of hatch or crx. I have some friends that put a b16 into an ef without custom mounts. Would this be possible or should I just buy the mounts. Also I had a friend tell me that because my car is OBD-0 that I would need to change my distributor to do the swap. Can any one help me out with these issues or any other issues I might run into doing this swap.
Re: B17A Into EF Civic or CRX (jdm_92_gsr)
You need the HASport or HCP mount kit. You need to swap out the dist, injectors, and the p61 for a PR3 and b16 injectors and dist. Or you can get an OBD0-1 conversion harness. Talk to Blown90hatch about that. If you want, PM B17A HATCH. He just did this swap.
