My H22 Civic keeps dying!!!!!!!
I replaced my battery and my alternator, and my car still dies after driving it for about 5 minutes. Why is it doing this????? Could it be the wiring? I had Suprdave do the harness, so I'm assuming it's correct. Any help is much appreciated. I'm so damn right now.....
Re: My H22 Civic keeps dying!!!!!!! (UpstateCivic)
hmm. you're not throwing any codes are you? and make sure the connection from the alternator to the battery is on there properly?
Re: My H22 Civic keeps dying!!!!!!! (poison)
I'm throwing 3 codes, IACV, knock and egr. Luckily I managed to coast into autozone so I could jump the car. I barely made it home (right around the block) before it did it again. It'll run for about 5 minutes, then you the tach stops working, the speedo stops, the blinkers go dim and then its done.
Is your alternator belt tight enough? If it's not, it's always going to die shortly after you start it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UpstateCivic »</TD></TR><TR><TD CLASS="quote">I'm throwing 3 codes, IACV, knock and egr. Luckily I managed to coast into autozone so I could jump the car. I barely made it home (right around the block) before it did it again. It'll run for about 5 minutes, then you the tach stops working, the speedo stops, the blinkers go dim and then its done.</TD></TR></TABLE>
Ok, I was just thinking you may be throwing the ELD but wasn't sure. That's an alternator connection problem going to the battery, or something to that effect.
Re: My H22 Civic keeps dying!!!!!!! (hot_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH »</TD></TR><TR><TD CLASS="quote">Is your alternator belt tight enough? If it's not, it's always going to die shortly after you start it up.
It's on there good and tight, I just double checked it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">The bigger white cable tightenened on the battery and the alternator as well as in good shape?</TD></TR></TABLE>
I replaced the alternator for him today. It is a remanufactured alternator forn NAPA. I did not test it at their shop before I installed it. I can pull it back off in 5 min and have it tested. The white wire on the harness looks to be good. I had my buddie hook the alternator testor to the car. It was not giving an output signal.
Slammed Ek9
05-02-2005 12:06 PM
ownedbyvtec
08-24-2003 01:18 AM
