HONDA EK H22 swap!
HONDA EK H22 swap!
Just a few last questions b4 i can finish my swap....HELP me out guys!!
1) What type of radiator for NORMAL daily driving!!
remove a/c for big one? or can i buy a fatter one?
2) What to do with the fuel rail? Is there a reverse to buy, or diff gas line?
3) I got 1.9 and 1.5 drop springs, which should i use in the front...engine is heavy...
4) Nology wires/bosch plugs sound oK?
5) anything else TO help me finish my baby!!, pics will b up SOOON!
Re: HONDA EK H22 swap! (Ddogz15)
Ok, I could just say 'do a search on H22 CIVIC' cuz that would answer all of these, but I will help out. . Here goes.
1) Del Sol VTEC is a dual core small radiator. It will work perfect. the stocker works great if you're not in a hot environment too..
2) Up to you. A 90 Accord fuel rail works, I believe. I jsut extended my fuel line. It's up to you.
3) Depends again on what you want. what kind of springs do you have? What do you want? a daily driver? a drag car? etc.?
4) That's more than fine. Stock wires/plugs work beautifully for these.
5) Be sure you check and re-check your wiring harness. that's the trickiest part. Good luck.
Tim said pretty much it. But let me answer 'em as well
1) Del Sol VTEC or Civic Automatic radiator with Spal slim fan, or get an aluminum radiator
2) Custom fuel line to reach from the fuel filter, or get a 90 acccord fuel rail.
3) You will want the 1.9 springs in the front and the 1.5 in the back. The front springs have a stiffer spring rate for a reason.
4) Sure. Drop the Bosch plugs though. Get some NGK's from Honda
5) What else do you need to know? I'm not sure the status of your swap. So more details and we can help you further.
Re: HONDA EK H22 swap! (poison)
1) What year DEL SOL for raditor?
2) Ill have to see what to do on the fuel rail...
3) I have TEIN springs...1.9 in the front it is...
thanks guys...ill be back if anything further comes up!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ddogz15 »</TD></TR><TR><TD CLASS="quote">1) What year DEL SOL for raditor?
thanks guys...ill be back if anything further comes up!</TD></TR></TABLE>
1) 94-97 del Sol VTEC dual core radiator. a 99-00 Civic Si radiator also will work.
2)
3) 1.9 is definitely the front. NP btw.
2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Tim said pretty much it. But let me answer 'em as well
Wait, AUTOMATIC Civic's have a dual core radiator? Never heard of that...I'll have to check my mom's Civic. heh heh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ddogz15 »</TD></TR><TR><TD CLASS="quote">B&M short shifter for prelude right?</TD></TR></TABLE>
personally i think the throw of the stock shifter is pretty short anyway.. does anyone use a short throw adapter on their h22 civic? oh and BTW.. is it just me or do the prelude cables feel alot smoother/better than the rod type shift linkages? i love that ****.. less missed gears!!
Re: HONDA EK H22 swap! (blackedoutcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackedoutcivic »</TD></TR><TR><TD CLASS="quote">
I love it stock.
And dude, you hit the nail on the head. I remember when Tom was spouting off about how the cables feel vague and gross...BS!! They a off the freakin chain.
I'll never go back to rods.
I love it stock.
