reliablity of this setup
Old May 14, 2003 | 05:09 PM
Yellb16crxsi's Avatar
Default reliablity of this setup
ok i want to biuld an ls/vtec.. i dont plan on reving it past 8200
stock b16a1 head
b18b bottom end
itr pistons
arp head and rod bolts
new type r oil and water pump
new seals and gaskets
and i was thinking of useing the tapered dowel rods that i have been seeing around on the board
any of your opinions and suggestions are welcome
Old May 15, 2003 | 06:14 PM
Default Re: reliablity of this setup (Yellb16crxsi)
ttt
Old May 16, 2003 | 12:07 AM
Formula 1's Avatar
if u not reving past 8200 y get ls/vtec...just get a gsr or b16...keep it stokc has enough HP and enough rpms for u...ls/vtec is for peeps squeekin ever hp outta the car not peopel rev to only 8200 and concerned wit realiablity ...just my thoughts on the subject
Old May 16, 2003 | 04:13 AM
J2turbo21's Avatar
If you plan on racing it every day its not gonna last as long compared to just a normaly driven car.It should last awhile though.
Old May 16, 2003 | 06:27 AM
10K2HVN's Avatar
Thats Set-up sounds very Good! ..but try to get the rods Shotpeened too..and check specs after shotpeening. if i had a LS block i would do:
B18B
B16 head (Type-R Valves and Lost Motion Assemblys)
JDM B16 pistions (highest OEM compression ratio next to CTR)
Shotpeened LS rods
CTR Cams
and No Short Cuts!!! ..build it correctly..! ..so LS/CR-VTEC doesnt get more bad rep!!!
edit: oh yeah, of course the ARP head and rod bolts new gaskets and seals and new bearing! ..a lot of talk about ACL bearings...(?)
Modified by 10K2HVN at 7:55 AM 5/16/2003
Old May 16, 2003 | 09:57 AM
Default Re: reliablity of this setup (10K2HVN)
how much does a set of shotpeened rods cost? and does anyone already sell them shotpeened?
Old May 16, 2003 | 04:49 PM
ttt
Old May 17, 2003 | 01:52 PM
10K2HVN's Avatar
you can just go to a machine shop and have it done..i think its like $100 bucks...but then you gotta get em checked...might cost more...
Old May 18, 2003 | 02:52 PM
another question i know that you have to take 1mm off each side of the rod but i would rather do that to the piston. how much do you all think that would cost?
jdm kidd
30
Jan 23, 2009 04:57 PM
1995Civiccx
Jul 16, 2007 04:44 PM
imskatencrzy
Sep 30, 2006 07:12 PM
OPTION2ek V.2
11
Apr 26, 2005 06:18 PM
H22CIVIC
Dec 5, 2001 04:00 PM
