How do I wire up the VTEC on a 90 integra with a B16 swap?
I was not sure if the harness that it will come with will work, so I figured I would ask!
Re: How do I wire up the VTEC on a 90 integra with a B16 swap? (Spoonin)
Nope. You need to use your 90 Integra harness since the JDM harness shock tower plugs are on the wrong side. Your 90 Integra harness will plug right ito the B16 and it'll work just fine. You'll just need to wire up 4 wires to the PR3/PW0 ECU that you run with the B16......
A8 - To VTEC solenoid
B5 - VTEC oil pressure switch
B19 - Knock Sensor
C8 - Secondary O2 wire
That's about it.
B19 - Knock Sensor
That's about it.
Re: How do I wire up the VTEC on a 90 integra with a B16 swap? (Newman)
could I put an O2 sensor eliminator kit on the second O2 wire?
No, the PR3/PW0 ecu needs both o2 sensors installed and in the proper location to work right.
Hybridize
10-17-2003 11:37 AM
