injectors and resistance for a pr4 ecu.
injectors and resistance for a pr4 ecu, aka the b20 integra doesn't want to idle.
With a PR4 ecu (90-91 integra), would I need to run the Honda injector resistor box when running OBD1 b16 injectors? Or are they pretty much plug any play with this ecu?
I was getting a CEL #16 (injectors) running my OBD2 GSR injectors, and the b16 injectors with 10w/10 ohm resistors doesn't want to idle.
Any ideas?
Modified by hypa at 2:53 AM 5/18/2003
Any ideas?
Re: injectors and resistance for a pr4 ecu, aka the b20 integra doesn't want to idle. (hypa)
you need to use an injector resistr and non obd injectrs.the obd1/2 injectors can fry you ECU.
Blaze
Blaze
Thanks for the reply Blaze. It's definately not what I was expecting, as I thougt that I could easily run OBD1 injectors. OBD0 injectors are going to be a pain in tha *** to find.
Can anyone confirm this?
Any other options available?
hybridb18
12-30-2010 06:20 PM
