Injector resistor box question....NEED HELP!!!!!!!!!!1
Just installed the GSR yesterday. I rewired for OBD 0 with my b16 harness, ECU, injectors, distributor, and o2 sensor. The problem im having is it starts up and dies immediatly. If i give it some throttle itl run. But it sounds like its runin on 2 cylinders. When i was droping in the motor the injector resister box got under the motor and i couldnt pull it out to the top again, so i cut it. theres 4 black wires and a red wire. DOES THE ORDER OF THE WIRES MATTER? does each black wire have to go to a specific black wire on the resistor box or just any black wire? Im almost 100 percent sure that thats the reason cause it runs at partial throttle on what seems like 2 cylinders. thanx.
