h22 throttle body on bseries manifold?
Will this work? Does a h22a throttle body bolt right on to a b series manifold without any modifications? What size is this throttle body?
Re: (b20ek)
Good call, industry secret maybe?
My old h22a t/body went on my friends b16a i/manifold no problem and he really likes it.
I may be wrong on the size though..it is either 62 or 64 mm in diameter..(I forget).
Re: (Rowdy)
... will the h22a throttle body bolt up to a skunk2 manifold also?... any other issues i should know about with the lude tb and skunk2 im (port matching, etc)... if it works, then this might be a better option for me then ghetto-diy-dremel-porting-boring my stock throttle body... lemme know... thanks...
Re: (1.8T_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8T_EG »</TD></TR><TR><TD CLASS="quote">... will the h22a throttle body bolt up to a skunk2 manifold also?... any other issues i should know about with the lude tb and skunk2 im (port matching, etc)... if it works, then this might be a better option for me then ghetto-diy-dremel-porting-boring my stock throttle body... lemme know... thanks...</TD></TR></TABLE>
im pretty sure it should fit. that's if the h22 fits b series other than b17 manifolds.. if the h22 tb doesn't fit, then the b series wouldn't either..
h22 tb is 60mm, teg type r is 62mm
Re: (GSRslowandswap)
Yes it bolts right up to the B-series intake manifold. Yes, it's 60mm. Yes, it's bigger over all but I don't think it's really worth it to put on.... kind of like putting GSR cams into your B16 - if there's a difference, it's almost none and not noticable when driving.
blackoutvtec845
05-11-2010 05:49 PM
