88 Civic swap?
Location: First in Flight, Type Rs of East Coast, NC, FL
88 Civic swap?
What are best mounts for installing B18B1 in 88 dx civic? Also, info needed on what wiring harness to use, or to tap into. Thanks
Re: 88 Civic swap? (v-attack)
HASport or HCP. Either will work good. As fas as the harness goes, you need to convert from dual point to MPFI. Do a search on that, and you also either need an OBD0-1 conversion harness, or you need to convert your dist, injectors and ecu to OBD0.
crx-si
09-01-2008 05:54 PM
demon_TEG
10-13-2004 03:50 PM
