92-95 ls swap into 92-95 civic...
Whats up guys, Iknow this has probably been answered many times before, but basically all I need to know is if this is a straight foward swap... I just bought the integra very cheap, and I want to find a hatch around the same year. Will I have everything for the civic from the integra??? What about the wiring and the ecm???Will I have to use the integra wiring harness, or will the civics work?? I plan on running my greddy turbo kit on the hatch wants the swap is complete... My goal for now is high 12 sec times on 9 psi with my turbo. I dont think it should be a problem since my 99 integra ls is going mid 13s @103 with 7 psi on street tires....Any info would be very helpful...
Re: 92-95 ls swap into 92-95 civic... (99lspwr)
Click on the search button, it really helps.
If you do get a 92-up Integra swap in your Civic make sure that the tranny is a hydraulic one(94-up).
12s should not be hard with that setup you have in mind. How big is the GReddy turbo?
Re: 92-95 ls swap into 92-95 civic... (lazy bum shaughn)
Sorry about the search thing, I was in a big hurry....But anyway the turbo is an 18g. I have it on my 99 ls right now, but I was thinking of ditching the car because I owe alot of money on it, and I am tired of car payments...I just bought the 95 ls integra very cheap, and I will be keeping my eyes open for a 92-95 hatch. Is there anything else I have to change between the 2 cars such as the wiring or clutch slave cyl.???
Re: 92-95 ls swap into 92-95 civic... (JV)
Will I have to use the integra wiring harness, or will the civic harness plug in to the tegs ecu, and all the sensors. I also heard something about wiring up a 4 wire o2 sensor, Is this true or do the 92-95 civics already have a 4 wire?
swap
So you are saying that the plugs on the civics harness will plug right in to the tegs ecu?? Man, this seems like a pretty easy swap, especially since I have the whole car to work with...Bought it cheap too!!!
New User
iM x Omar
58
09-15-2008 11:46 AM
Thats-so-Ls
08-25-2001 09:37 PM
