obd question?
Old May 11, 2003 | 07:07 PM
98silverhatch's Avatar
Default obd question?
a 95 integra ls swap is a obd1 setup, my car is obd2. can the obd1 integra motor be swapped in without using a jumper harness?
Old May 11, 2003 | 07:15 PM
H22EK's Avatar
Default Re: obd question? (98silverhatch)
no, ECU plugs are different
Old May 11, 2003 | 07:22 PM
Default Re: obd question? (H22EK)
if the ls ecu is included too?.
Old May 11, 2003 | 07:28 PM
poison's Avatar
the ECU plugs are not the same and will not plug in. You will need to convert your car to OBD1 to run that.
frankiecutz
Engine Management and Tuning
Oct 4, 2010 01:15 PM
heeltoehonda
Nov 19, 2009 11:41 AM
A-TL
Jan 22, 2006 01:14 PM
RedTegLS
Nov 17, 2003 11:58 AM
