Piston/valve clearance question..
New User
If we use ITR pistons in a B18A black, with a B16A head, will there be any clearance issues or will it be ok?
2001 ITR pistons/rings
1993 B18A block
1991 B16A head
Thanks in advance
Jay
1993 B18A block
1991 B16A head
Thanks in advance
Jay
Re: Piston/valve clearance question.. (CanuckCRX)
You'll be fine with VTEC pistons. Reason being is because the valve relief is deeper on the VTEC pistons, giving more clearance. If you look at a SiR/Type R piston next to a LS/B20 piston, you'll see how shallow the LS/B20 piston valve relief is, and you'll know why it's not really recommended to run "big" cams with those pistons. Check out what I posted up yesterday, and the pict I threw up (the marks on the intake side of the piston) - https://honda-tech.com/zerothread?id=504965
New User
Re: Piston/valve clearance question.. (Newman)
Thanks Newman...so I will be ok with the B18A rods and the ITR pistons...good news.
Thanks again for the help guys.
Canuck
Canuck
ATS_Antone
05-15-2008 08:03 PM
JCushing
10-23-2002 04:56 PM
