h22 v tec head on h 23 ?
im told it can be done? do you think it will make it to 190hp or more? its supossed to add 100cc. will i need the a new ecu and harness to control it? where can i get a h22 v tec head.
trying to put it on a 94 lude si
thanks
thanks
yes it can be done,but 100 cc i don't see that happening.you can go with a reprogrammed p28 ecu and,you can use the same harness,just add the vtec wires and run them to the computer or check to see if they are in the harness passenger side.
take your time and ask questions if your not sure.
Re: (1700anddroping)
yes it can be done. You need vtec wiring get a p13 not a p28 unless you eliminate your secondaries because p28 will not contrl them, or you could get a p72 and chip (which I have if your interested)p14 pistons are shitty as far as comp. goes, so you might want to change them. Also you will need all the timing gears and tensioners and **** like that to do it
Alpinestar03
02-21-2008 02:39 PM
