lsvtec into an ek - which shift linkage???
Old Jan 7, 2004 | 11:03 AM
ID_ten_T's Avatar
Default lsvtec into an ek - which shift linkage???
quick question, i am pulling an lsvtec from a delsol and putting it into an 96 civic ex. i was wondering which shift linkage i could use. i searched and got conflicting info. will the stock civic shift linkage work? what about the delsol? if neither of these will work, which shift linkage should i look for? thanks.
Old Jan 7, 2004 | 11:49 AM
JDMH22HATCH's Avatar
Default Re: lsvtec into an ek - which shift linkage??? (ID_ten_T)
Use 99-00 SI shift linkage. The del sol linkage will not work and neither will your stock d-series.
Old Jan 7, 2004 | 01:45 PM
ID_ten_T's Avatar
Default Re: lsvtec into an ek - which shift linkage??? (JDMH22HATCH)
i might have access to an integra shift linkage. would any integ linkage work or is there a specific integ linkage? thanks.
Old Jan 7, 2004 | 01:55 PM
jdmkevin's Avatar
THe integra likage will work
Old Jan 7, 2004 | 03:42 PM
thad
Guest
Posts: n/a
Default Re: lsvtec into an ek - which shift linkage??? (jdmkevin)
if you mean the del sol vtec linkage it should fit just fine.
any b-series rod linkage will work
Old Jan 7, 2004 | 07:26 PM
VTECVillain's Avatar
Default Re: lsvtec into an ek - which shift linkage??? (thad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thad &raquo;</TD></TR><TR><TD CLASS="quote">if you mean the del sol vtec linkage it should fit just fine.
any b-series rod linkage will work</TD></TR></TABLE>
The Del Sol VTEC shift linkage will only work in a Del Sol with B series, they are not the same length as the EG/EK B series linkage. The 90-93 DA Integra linkage will not work either.
For any Civic EG/EK B series swap, the proper linkage is the USDM 94-01 Integra or 99-00 Si, or the JDM Civic EG/EK or Integra DC linkage only.
Old Jan 7, 2004 | 07:49 PM
thad
Guest
Posts: n/a
Default Re: lsvtec into an ek - which shift linkage??? (VTECVillain)
i stand corrected
Old Jan 8, 2004 | 02:32 AM
b00sted93Hatch's Avatar
DC shift linkage will not work Period. I've came accross this before and its to short or was it to long dont remember. MUST use a 99-00 si.
Old Jan 8, 2004 | 04:01 AM
Default Re: lsvtec into an ek - which shift linkage??? (allMotor93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allMotor93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">DC shift linkage will not work Period. I've came accross this before and its to short or was it to long dont remember. MUST use a 99-00 si.</TD></TR></TABLE>
My close friend has a 96 CX with a second gen JDM B16A. I installed everything and rounded up the parts for him. I bought brand new linkage rods from Acura for a 1994 Integra LS, it fits perfect. Are you sure that you had the linkage from a DC Integra?
Old Jan 8, 2004 | 06:29 AM
CRITTERMATT's Avatar
I bought a b16 del sol tranny and shift lnkage from a member on here. i have not installed it yet. He had the shift linkage in hie ek and he told me it worked fine. As long as it is a DOHC shift linkage from a sol.
Old Jan 8, 2004 | 06:31 AM
Stroker
Guest
Posts: n/a
Default Re: lsvtec into an ek - which shift linkage??? (CRITTERMATT)
I have a del sol linkage in my ek. It works fine.
Old Jan 8, 2004 | 06:14 PM
Default Re: lsvtec into an ek - which shift linkage??? (stroker)
This is all from personal experiece so hear goes. First swap i had was a B16 from a del sol in to a 92-95 hatch. With this shift linkage it was to short. Had to swap that to a 94-01 gsr. Next was a 97 gsr swap into a Ek. I'm positive this was GSR shift linkage since I pulled it out of a wrecked gsr and it also has a dual bend shifter. I'm not sure how you got it to work but Mine wouldnt. This was few months back so i dont remember if it was to short or to long. I'm thinking that the 99-00 si shiftlinkage and the Del Sol Vtec shiftlinkage is the same but I dont have any laying around to compare. Since you order from acura it had to be a integra so I'm lost to how it fit.
b16delsolnewb
Apr 1, 2008 05:31 PM
BRG+Honda=JDM
Jun 22, 2007 11:25 PM
skiracer8148
Mar 17, 2007 05:09 PM
turbodelsol3
Mar 9, 2007 11:57 PM
93civic_b18b1
Aug 27, 2001 02:09 PM
