h22a usdm wiring question
i am using the usdm motor so i had to wire up a external coil. What i did was i took the Yellow wire from the coil and connected it to the yel/black wire on the distributer, then i connected the yel/blk wire from the coil to the other end of that yel/blk wire i cut from my harness (which originally went to the dist on the civic) that way i had a 12v source. Then i wired the Blue wire from the coil to the blue at the distributer, but i wasn't sure if i was suppose to eliminate the connection that the blue wire had before, which was from the civic dist into the wiring harness. do i just splice the 3 together? or just go directly from coil to dist and elminate the blue wire that goes into the harness? Any ideas?
Re: h22a usdm wiring question (nema741)
the blue wire from harness goes to the distributor not the coil you dont touch the blue wire.
the black/yellow wire is in the right location.
to add a negative to coil add the green wire that comes out the h22 distrrributor. its located in the corner of the big plug of the two distributor plugs
Re: h22a usdm wiring question (H23vtecEG)
Ok thanks, i'll re-wire the blue up, and change over the green. Hopefully i'll be ready to try to start her up tommorow so i'll let you know if it worked.
nocturnal EG
Audio / Security / Video
16
11-03-2006 08:04 AM
I8ayellowcrayon
05-24-2004 08:21 PM
H23vtecEG
10-14-2003 05:02 PM
