92 cx harness with LS swap, O2 sensor different
i have a problem O2 sensor on a 92 cx only has one wire and the integra has 4 wire what should i do use the civic wire, will it make any difference when used with 94 ls ecu. I know i will have to cut the wire and extend it to reach the back.
one more thing my cx throttle cable is too short, i wanted to use an LS throttle cable but the end assembly that attached to the pedal is different configuration
Re: 92 cx harness with LS swap, O2 sensor different (EGhybridHB)
You must wire up the 4 wire O2 from the LS, or any 4 wire O2 for that matter. The LS ECU looks for a 4 wire O2 so if you use the 1 wire CX O2, it would be the same as not even having one hooked up. Search on here, it's been cover quite a lot by me and a few others. You should have no problem finding instructions/wiring on how to change to the 4 wire.
mingchi96
12-02-2001 10:38 PM
