need help what intake manifold gasket????
i am doing a b20 swap into my 95 civic coupe.
now what intake manifold gasket should i use when swapping over the IM from my old b18b to the b20z????? please someone answer this for me i am pretty sure thats all i need to kno everything else seems to be a bolt on affair
i have the tranny, axles, ls ecu, and everyhting else needed for the swap. just need to kno what IM gasket i need.
thanks for any answers
-cliff
-cliff
Re: (dragboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragboy »</TD></TR><TR><TD CLASS="quote">integra mounts will work on teh car correct?????</TD></TR></TABLE>
Swapping the B20Z into your 95, you'll need to use a 94-01 Integra driver's side mount bracket and mount. You can use your stock upper tranny mount but you will need a 94-01 Integra rear mount bracket, front tranny bracket and A/C bracket. If you want to keep A/C then you'll need a Del Sol VTEC A/C bracket.
Re: (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
Swapping the B20Z into your 95, you'll need to use a 94-01 Integra driver's side mount bracket and mount. You can use your stock upper tranny mount but you will need a 94-01 Integra rear mount bracket, front tranny bracket and A/C bracket. If you want to keep A/C then you'll need a Del Sol VTEC A/C bracket.</TD></TR></TABLE>
ok cool so basically the same mounts i used on my b18b swap are going to be used........ thanks guys going to go pick up the 2.0 beast this morning thanks to EKsnatchback
Re: (dragboy)
just picked up the motor and its pretty damn good condition.
875 total wit tax for the motor and its a 99 b20z with 64k on it. not bad mileage and from a auto. i am giong to replace the IM gasket of course,exhaust manifold gasket, plugs, wires, cap, rotor, anythign else i should replace while imma at it???
if any ideas someone hit me up.
Re: (dragboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragboy »</TD></TR><TR><TD CLASS="quote">just picked up the motor and its pretty damn good condition.
if any ideas someone hit me up. </TD></TR></TABLE>
Might as well do the timing belt and water pump while it's all easily accessible.
Re: (JV)
would a b18b waterpump werk then cause my b18b has a new waterpump on it lol. id change it then maybe but since my buddies are helping me do the swap for free i dunt wanna bother them by doin harder werk.
o well hopefully wit the setup i will b able to hit mid 14s all motor with the b18b i was able to do a best of 14.7 so 14.5 is my goal all motor with just intake/exhaust and clutch was thinking of juicing this motor too, but nah its for sale anyone want it?????
itsjdmbradyo!
09-20-2006 10:21 AM
CHAMPwhteEK
03-10-2006 04:58 PM
BlueR
09-17-2003 07:02 PM
