another swap in an ek
Old Dec 27, 2003 | 07:28 PM
ci9v7ic's Avatar
Default another swap in an ek
just finished another swap. 1998 jdm b18c, b16 lsd tranny. check it out.
Old Dec 27, 2003 | 09:27 PM
Team 4R's Avatar
Default Re: another swap in an ek (ci9v7ic)
care to share the problems and issues and details of the swap? i´m attempting to do the exact same thing...... congrats either way.
Old Dec 27, 2003 | 09:31 PM
Kamin's Avatar
your avatar is backwards
and nice clean swap, good job keeping AC and PS
luxury items rule.
Old Dec 27, 2003 | 10:18 PM
ci9v7ic's Avatar
Default Re: another swap in an ek (Team 4R)
as long as you have the right mount brackets, mechanically its easy to install. the motor is obd-2 and didnt have a vtec pressure sensor so i had to change that. use the obd-2 dizzy, alt., injectors, with an ex harness. then you will have to wire up the secondaries, and change the iat plug and extend it. i had to extend my o2s too. if you want to keep the a/c, use the del sol a/c bracket with the d-series a/c comp. use the 99-00 si ps pump. i used an obd-1 gsr computer because the jdm motor has no crank angle sensor and the obd-1 comp didnt require it. thats all i can think of for now but feel free to ask any other questions. good luck!
Old Dec 27, 2003 | 11:21 PM
LukeDanger's Avatar
great job, i just got done doing the same swap tonight.
Old Dec 27, 2003 | 11:26 PM
ci9v7ic's Avatar
Default Re: (LukeDanger)
thanks! do you have pics of yours?
Old Dec 28, 2003 | 09:39 AM
TotalJDM.com's Avatar
Default Re: (ci9v7ic)
Nice clean engine!
Old Dec 28, 2003 | 11:20 AM
ci9v7ic's Avatar
Default Re: (TotalBoost)
this motor is exceptionally clean! it only has 10k on it.
Old Jan 5, 2004 | 06:56 PM
ci9v7ic's Avatar
Old Jan 6, 2004 | 12:54 PM
Wazup's Avatar
where did u get the motor from? and how much?
Old Jan 6, 2004 | 03:03 PM
ci9v7ic's Avatar
Default Re: (Wazup)
my motor is jdm. i sell the motors on the side. 3300.00 complete swap.
Old Jan 7, 2004 | 12:53 AM
J_SpeC_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">my motor is jdm. i sell the motors on the side. 3300.00 complete swap.</TD></TR></TABLE>
can u get ITR motors? if so how much?
Old Jan 8, 2004 | 03:16 PM
ci9v7ic's Avatar
Default Re: (J_SpeC_EK)
i can get an itr motor but it would take some time. i usualy get those, as they are ordered being how thats too much money to sit on. i'll have to check the price.lmk if you are serious.
jonbernard1234
Aug 17, 2009 08:36 PM
davidduarte
Nov 27, 2007 08:22 PM
Harrold
Aug 2, 2007 03:53 PM
jdmek9imagex
10
Oct 22, 2006 03:28 PM
Devilry
Nov 18, 2004 07:23 AM
