all pr4 ecu's the same?
Old Jan 8, 2004 | 02:21 PM
yellowCRX6's Avatar
Default all pr4 ecu's the same?
i plan on using one with a b18b in my crx si, and i know it will have to go from obd0-obd1, and i was curious if all the pr4's were the same, even if they come from different year tegs?
Old Jan 8, 2004 | 04:16 PM
flat-blk-HB's Avatar
Default Re: all pr4 ecu's the same? (yellowCRX6)
90-91 OBD0
92-93 OBD1
Old Jan 9, 2004 | 04:17 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowCRX6 &raquo;</TD></TR><TR><TD CLASS="quote">i plan on using one with a b18b in my crx si, and i know it will have to go from obd0-obd1,</TD></TR></TABLE>
The B18B1 doesn't have to be installed with OBD1 electronics unless you want to do that. I have a 96 B18B1 in my 91 CRX DX and I used all OBD0 electronics: 91 Integra distributor, 90 PR4 ECU, 90 CRX Si injector with resistor box. It's a lot easier that way, but depending on your future plans (boost, Hondata, etc.) you may want to go OBD1. As mentioned the PR4 was available as 90-91 OBD0 and 92-93 OBD1.
Old Jan 9, 2004 | 09:21 AM
yellowCRX6's Avatar
Default Re: all pr4 ecu's the same? (VTECVillain)
well i might go boost on the stock motor, run about 7 psi.... but thats for later. ill probly go with the 90-91 and keep it obd0. Whats the comparison of the pr4 to a p74 or p75?
1_slow_crx
Feb 13, 2007 07:52 PM
bnoland
14
Jul 22, 2006 11:04 AM
honcrx91si
Aug 8, 2005 08:23 PM
kurinto
Jun 11, 2004 10:16 PM
slvrstns2000
Nov 18, 2003 06:23 AM
