timing question
Old Dec 27, 2003 | 03:13 PM
jdm_gsr's Avatar
Default timing question
i having a lil problem on my timing i just bought a b16 timing belt from honda and when i put it on i dont under stand why the timing skiped. when i started it up it was idolin fine then i reved it up a lil like to 4500 rpm then it skiped.
b16 block and b16 water pump
Old Dec 27, 2003 | 09:32 PM
Kamin's Avatar
Default Re: timing question (jdm_gsr)
you didnt tension it properly
do it again, this time before you start the motor, crank it over by hand 10 times or so.
Old Dec 28, 2003 | 05:06 PM
jdm_gsr's Avatar
how u tension it properly
Old Dec 28, 2003 | 06:33 PM
IS3Fifty's Avatar
Default Re: timing question (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">you didnt tension it properly
do it again, this time before you start the motor, crank it over by hand 10 times or so.</TD></TR></TABLE>
just like that.
Old Dec 29, 2003 | 04:19 PM
jdm_gsr's Avatar
i just did that today and i drove it and it cut off on me and the timmin skiped....... i cranked it over 10 times by hand and arm. and timin was still ok i drove it down the street when it was in 4th gear going about 40 mph it cut off on me sooo what now
Old Dec 29, 2003 | 04:33 PM
Kamin's Avatar
Default Re: (jdm_gsr)
http://www.helminc.com
get a service manual, follow the instructions for tensioning it.
Old Dec 29, 2003 | 07:57 PM
jdm_gsr's Avatar
naw man i giv up thank u doe ima just take it to teh shop i give up lol
Old Dec 30, 2003 | 01:06 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_gsr &raquo;</TD></TR><TR><TD CLASS="quote">i just did that today and i drove it and it cut off on me and the timmin skiped....... i cranked it over 10 times by hand and arm. and timin was still ok i drove it down the street when it was in 4th gear going about 40 mph it cut off on me sooo what now </TD></TR></TABLE>
You don't need to crank it 10 times, 3-4 will be more then enough to seat the belt. The purpose of cranking it over is not to "tension" the belt, its to seat it and line it up with all the various pulleys correctly. There is a tensioner bolt just above the crank pulley towards the firewall. Its usually got a rubber plug in the hole covering it up. Remove the plug and expose the bolt. Its a 14mm head. Loosen it about 1 full turn. Do NOT overloosen it. Now, rotate the crank (not the cams) four full turns COUNTERCLOCKWISE. On the last turn, line the marks on the cams so the "UP" faces up. Make sure the crank is also on TDC. If all checks out then rotate the crank an additional *3 teeth* on the cams COUNTERCLOCKWISE and stop. Tighten the tension bolt to approx 40ftlbs. Your done.
Old Dec 30, 2003 | 10:56 PM
jdm_gsr's Avatar
dang u smart ahah but thanks ill try that tommorw
Old Dec 31, 2003 | 12:26 AM
JCracer723's Avatar
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
You don't need to crank it 10 times, 3-4 will be more then enough to seat the belt. The purpose of cranking it over is not to "tension" the belt, its to seat it and line it up with all the various pulleys correctly. There is a tensioner bolt just above the crank pulley towards the firewall. Its usually got a rubber plug in the hole covering it up. Remove the plug and expose the bolt. Its a 14mm head. Loosen it about 1 full turn. Do NOT overloosen it. Now, rotate the crank (not the cams) four full turns COUNTERCLOCKWISE. On the last turn, line the marks on the cams so the "UP" faces up. Make sure the crank is also on TDC. If all checks out then rotate the crank an additional *3 teeth* on the cams COUNTERCLOCKWISE and stop. Tighten the tension bolt to approx 40ftlbs. Your done.</TD></TR></TABLE>
i dont get this... i did my belt with the engine out ... took the old belt out.. put the new 1 in.. line it all up (didnt have to move any pulleys since i didnt messed with them when takin the old 1 out) tighten the teniosn bolt and checked if everythin was lining right and it did... is this right??? btw this is on a single cam
Old Dec 31, 2003 | 10:38 AM
Hybrid96EK's Avatar
Default Re: (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">
i dont get this... i did my belt with the engine out ... took the old belt out.. put the new 1 in.. line it all up (didnt have to move any pulleys since i didnt messed with them when takin the old 1 out) tighten the teniosn bolt and checked if everythin was lining right and it did... is this right??? btw this is on a single cam</TD></TR></TABLE>
Tensioning procedures are similar on a SOHC as well. You are still supposed to rotate the crank 3 times to make sure the belt is seated on the pulley, regardless of what you did. It has nothing to do with the engine being hot either. You are also supposed to rotate the cam 3 teeth counterclockwise off of TDC and THEN tighten the tensioner. Failure to do so may allow excessive slack in the system.
Old Dec 31, 2003 | 02:54 PM
JCracer723's Avatar
i did it... and it felt the same ... before i did it... i felt the tenion on the belt.. (felt the 1/4 play on the belt) .. then after i was done.. it felt the same .. still the 1/4 play ..
Old Dec 31, 2003 | 03:02 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">i did it... and it felt the same ... before i did it... i felt the tenion on the belt.. (felt the 1/4 play on the belt) .. then after i was done.. it felt the same .. still the 1/4 play .. </TD></TR></TABLE>
I won't say that it can't work any other way. I am simply stating how Honda says it should be done.
Old Jan 1, 2004 | 11:25 AM
JCracer723's Avatar
so does the tension of 1/4 turn play sounds ok?? ive read it in a couple of post here
Old Jan 1, 2004 | 11:48 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">so does the tension of 1/4 turn play sounds ok?? ive read it in a couple of post here</TD></TR></TABLE>
Yes, sounds fine.
marecco
Sep 7, 2007 01:12 PM
boomersz
Mar 4, 2007 09:09 AM
Lissav
May 11, 2006 08:09 PM
E.Honda
16
Dec 9, 2005 07:22 PM
todaspecsi
10
Apr 20, 2004 12:03 PM
