difference between b18a and b?
Old Jan 5, 2004 | 08:14 AM
fernancivic's Avatar
No Sales Forums
Default difference between b18a and b?
is there a difference between the two other than the year made?
Old Jan 5, 2004 | 08:24 AM
Colin's Avatar
Default Re: difference between b18a and b? (CFT-Si)
there are differences, but most of the time its irrelevant to what it takes to install them. are there certain parts you're wondering about?
VTECVillain's Avatar
Yes there are quite a few differences:
1990-91 B18A1 uses OBD0 electronics, smaller ports on the intake manifold/head, etc.
1992-93 B18A1 is the same motor as the 90-91 except with OBD1 electronics.
1994-95 B18B1 is OBD1, newer designed head with better flowing manifold, bigger ports, etc.
1996-99 B18B1 is the same as the 94-95 except a few added sensors for OBD2 emissions.
2000-01 B18B1 is the same as the 96-99 except OBD2B
Old Jan 5, 2004 | 08:26 AM
Colin's Avatar
Default Re: difference between b18a and b? (VTECVillain)
there are some other minor differences between the 90-91 and 92-93 motors. nothing huge.... but they are there
-couple sensor's are different
-trannies are different (not sure if he's including tranny... but since you included electronics...)
-manifolds are different
Old Jan 6, 2004 | 11:25 AM
No Sales Forums
the reason i was asking is because im building a lsvtec. im using my 99 si head with a b18a block that i got cheap. but im about to send the block to get sleeved with darton sleeves and wanted to make sure it would alll come together with no problem.
Old Jan 6, 2004 | 05:46 PM
No Sales Forums
bump
Old Jan 10, 2004 | 11:59 AM
yellaboi's Avatar
as far as bare blocks go, there is no difference
Old Jan 10, 2004 | 12:42 PM
4genaccordfreak's Avatar
so.. when going LS/V what would everyone choose to be there block.. B18a which is alot cheaper.. or spend more money to get a b18b!??
Old Jan 11, 2004 | 11:38 AM
yellaboi's Avatar
Default Re: (4genaccordfreak)
get the cheaper one.
Old Jan 11, 2004 | 01:28 PM
Colin's Avatar
Default Re: (yellaboi)
yup, considering you'll be rebuilding the whole thing anyway.... just start with whatever you can get the best deal on.
89luderSi
Nov 3, 2009 08:21 PM
turbo_d
Jul 7, 2008 08:35 AM
NateTEG95
Dec 15, 2002 02:49 PM
HondaCutter
Jul 22, 2002 09:13 AM
