do i need motor mounts?
Old Jan 4, 2004 | 12:34 AM
ownedbyvtec's Avatar
Default do i need motor mounts?
i have a 92 vx and plan on a b16a2 swap do i need motor mounts???..and if i do,what car can i use the mounts from? also do i need axles and from what car?
Old Jan 4, 2004 | 11:38 AM
jobin's Avatar
Default Re: do i need motor mounts? (ownedbyvtec)
you can use the stock end mounts (driver passenger) but you need 94 up integra front and rear mounts
Old Jan 4, 2004 | 05:24 PM
hybrid racing's Avatar
you need a rear mount bracker from an integra.... you will need a engine mount and bracket for the timming belt side from an integra the transmission mount will work you will also need a new ac bracket from a 95 delsol with the b16 and the same front tranny bracket if you want to keep all 5 mounts...
Old Jan 4, 2004 | 05:57 PM
VTECVillain's Avatar
This always seems to help, courtesy of Katman:
Old Jan 10, 2004 | 01:45 AM
jobin's Avatar
Default Re: do i need motor mounts? (VTECVillain)
thats awsome having the big picture and ****
Old Jan 10, 2004 | 11:06 PM
egizzle8
Guest
Posts: n/a
Default Re: do i need motor mounts? (jobin)
I was just about to post the same question but for a 92 LS into an EG but assuming it'll be the same mounts right? What about axles and linkages?
Old Jan 10, 2004 | 11:39 PM
92b16vx's Avatar
Default Re: do i need motor mounts? (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">I was just about to post the same question but for a 92 LS into an EG but assuming it'll be the same mounts right? What about axles and linkages? </TD></TR></TABLE>
Use the ones from the motor.
Old Jan 10, 2004 | 11:42 PM
egizzle8
Guest
Posts: n/a
Default Re: do i need motor mounts? (92b16vx)
Thanks homie!
Old Jan 11, 2004 | 04:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 &raquo;</TD></TR><TR><TD CLASS="quote">I was just about to post the same question but for a 92 LS into an EG but assuming it'll be the same mounts right?</TD></TR></TABLE>
For a 92 LS it depends if you are using the LS cable tranny or a hydro tranny. If you are using the cable tranny then you'll need to get the HASport hydro to cable kit which has the mounts needed. If you're using a hydro tranny then use all the mounts from the above pic. The driver's side bracket and mount on the B18A1 must be changed to the 94+ Integra if you want it to bolt in properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What about axles and linkages? </TD></TR></TABLE>
Get a 94-01 Integra shift linkage, the 90-93 will not work. For axles it depends on what intermediate shaft you use. If you don't have one yet, get a 94-01 Integra shaft and both axles OR you can also use a 90-93 shaft with 90-93 axles.
Old Jan 11, 2004 | 01:00 PM
Turbogixxer's Avatar
VTECVillain is right again
Old Jan 11, 2004 | 02:01 PM
Newman's Avatar
New User
Basically the same setup that we're running in an EG coupe.... 98 LS block with a 93 YS1 GSR cable tranny, using the HCP EG-18C kit. Been like that for over 3 years now and it's a daily driver with a stock ITR clutch. I've even launched the car at the track a few times and it's held up just fine. Use 94+ Integra shift linkage and you can reuse the 90-93 Integra axles if you want to... just use the same mid shaft.
FunForFree33
Jan 26, 2011 08:51 PM
anzh86
Jul 23, 2010 09:20 PM
SPD DMN
Sep 20, 2006 01:50 PM
92CiviC4dr
Mar 2, 2006 08:04 AM
roc109
Jan 8, 2003 01:46 PM
