answer my quick question please
Old Jan 6, 2004 | 03:16 PM
genop's Avatar
Default answer my quick question please
ok, I am getting a d16z6 motor from a 95' del sol and I have a d16y7 tranny out of a 97' civic. My question is this, will that motor and tranny set-up drop right into a 97' civic without any mods?
Old Jan 6, 2004 | 03:30 PM
VTECVillain's Avatar
Default Re: answer my quick question please (genop)
Yes but you will need to change the driver's side engine bracket and mount on the Z6 to a 96-00 bracket and mount. Other than that, the tranny will bolt to the motor and with the bracket/mount change, it'll drop right into the car.
Old Jan 6, 2004 | 04:12 PM
genop's Avatar
Default Re: answer my quick question please (VTECVillain)
Thank you very much. I have one more question, will the ecu from the 97' civic work or do I need to change the ecu to run this motor?
Old Jan 8, 2004 | 03:49 AM
genop's Avatar
anyone? I know someone can answer this for me.
Old Jan 8, 2004 | 04:08 AM
The best ECU to run would be an OBD1 P28, but you will need an OBD2 to OBD1 ECU adapter. What model is the 97 Civic? If it's an EX or has a 96-98 EX ECU then you could use it but you will have to add some extra wiring for the extra OBD2 sensors (2nd O2, Crank Fluctuation, etc.)
zccivicex
Jun 10, 2009 02:09 PM
ej1 pilot
Nov 10, 2008 11:14 AM
civicmobileone
Apr 25, 2007 12:38 PM
delsol2005
Aug 1, 2005 04:11 PM
MHhonda99
Jan 7, 2002 12:59 PM
