battery doesnt fit with b16/ef swap.....now with pictures
i asked before and people said they haven't heard of this problem, i took some pics of my situation
i bought the mounts off the internet from some company in canada...they look to be decent quality
the clutch cable bracket and cable itself are in the way
in the second pic you can see how the battery tray will not sit level
Re: battery doesnt fit with b16/ef swap.....now with pictures (drew2)
Thats odd. I've never seen that. I'd relocate the battery to the hatch if it won't fit there anymore. The odyssey racing battery is slimmer so it might fit there. You would have to trim the plastic tray.
http://crx.honda-perf.org/arti....html
Re: battery doesnt fit with b16/ef swap.....now with pictures (PhatOptimo)
Chop the tray, because the battery should still squeeze in there just fine. Or do a relocation..
I did a write up.. see if this helps.
http://www.homemadeturbo.com/t....html
The battery tray isn't level because it's caught on the clutch cable. You're going to have to notch the battery tray for clearance of the clutch cable then see if the battery will fit. I'm not too impressed wit this mount kit to say the least.
drew2
14
11-30-2003 04:15 PM
travis
02-06-2002 07:32 PM
