B series into 91 accord
I am planning on buying a K1 Attack kit car, it has the same engine mounts as a 90-93 Accord. I am thinking of building a turbo B series Dart engine, big bore and tall deck.
I was wondering if the F series motor mounts the same way the B series does, and more importantly, do they lean the same direction? I think I heard a while ago that the H / F series tilts forward more than B series engines.
Do you guys know if B series engines can fit H or F series trannies? I am assuming no.
Please do not suggest I use a F or H series engine, thanks but I have already looked into it. Weight and power of the two options do not appeal to me, and in a 1800 pound car the weight difference is noticeable.
Thank you for the help, nice forum by the way.
Re: B series into 91 accord (stroker)
It is going into a tube framed rear engine car, moving motor mounts is easily done. I was also assuming I would need custom axles.
Modified by dustind at 11:00 AM 1/4/2004
Guest
Posts: n/a
Re: B series into 91 accord (dustind)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustind »</TD></TR><TR><TD CLASS="quote">It is going into a tube framed rear engine car, moving motor mounts is easily done. I was also assuming I would need custom axles.
Modified by dustind at 11:00 AM 1/4/2004</TD></TR></TABLE>
BAHHAAAHHH ok then why are you asking us. LOL
Grandhustleman86
03-04-2007 07:45 AM
