swap is in.... need help with problems
Old Jan 9, 2004 | 11:48 AM
Team 4R's Avatar
Default swap is in.... need help with problems
okay, the jdm gsr is in but there are some issues with it..... it didn't crank over until the third attempt and it let out a loud popping sound before firing...... the idle is terrible, it sounds like a domestic with huge cams..... beyond that there is a LOT of vibration, especially from the timing belt side..... what could be the problem?
Old Jan 9, 2004 | 11:50 AM
Team 4R's Avatar
Default Re: swap is in.... need help with problems (Team 4R)
update: it starts okay, but with a little gas it is definitely backfiring...!! is my timing off?!
Old Jan 9, 2004 | 11:53 AM
iplaybass's Avatar
most likely. do you have a timing gun? Are your plug wires on correctly?
what kind of car is this in?
Old Jan 9, 2004 | 12:03 PM
Team 4R's Avatar
Default Re: swap is in.... need help with problems (iplaybass)
might be that my #2 and #3 wires are crossed...... the firing order is 1-3-4-2 from lower left going counterclockwise, right (on the dizzy cap, i mean)?
Old Jan 9, 2004 | 12:23 PM
iplaybass's Avatar
it should be 1-3-4-2, does your setup look like this?
3 4
1 2
Old Jan 9, 2004 | 12:45 PM
Team 4R's Avatar
no, the #2 and #4 wires were reversed...... i changed them around, but now the motor just wont start.
Old Jan 9, 2004 | 12:58 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iplaybass &raquo;</TD></TR><TR><TD CLASS="quote">it should be 1-3-4-2, does your setup look like this?
3 4
1 2</TD></TR></TABLE>
That is correct, you do a timing belt too?
Old Jan 9, 2004 | 01:33 PM
iplaybass's Avatar
lets start out fresh, what kind of vehicle, and what engine/ecu are you using.
Old Jan 9, 2004 | 03:06 PM
Team 4R's Avatar
okie dokie.... got it started. turns out the wires were crossed.... corrected them and now it's running. thanks.
Old Jan 9, 2004 | 03:20 PM
eg6h8k's Avatar
good job...i did the same thing changing my cap and rotor..it was LOUD as POP..it scared the crap outta me..i though something seriously whenn wrong..but its all good after i corrected the wires...
h23prelude94
Sep 1, 2008 08:59 AM
Powered by VTEC
Jan 25, 2008 01:05 PM
93-lsvtec-eh2
Apr 2, 2007 02:48 PM
DB1_559
Jul 3, 2006 04:00 PM
importlegions
Jul 29, 2004 11:28 AM
