alternator help b16a
Old Jan 12, 2006 | 10:00 AM
aaronhume's Avatar
Default alternator help b16a
hello, I have a non-obd b16a and the alternator just blew up. I tried replacing the brush set, but still did not fix the problem. i called a local honda junkyard and they are out of the 90-91 integra (b18a) alternators, but do have a 94 ls alternator. I would assume they bolt right in, but are the plugs different? if so are there the same number of wires so I can swap plugs? thanks! (btw: my car is an 89 civic dx non-obd obviously)
Old Jan 12, 2006 | 07:44 PM
aaronhume's Avatar
Default Re: alternator help b16a (aaronhume)
bump
Old Jan 12, 2006 | 08:21 PM
jdmcars.com's Avatar
The 94 will bolt up and plug right up fine. OBD1 & OBD0 alt use same wiring clips, OBD2 is the change for the green clip.
Anyways, the 94 is
Old Jan 12, 2006 | 08:38 PM
aaronhume's Avatar
Default Re: alternator help b16a (jdmcars.com)
ah excellent thanks!
aasarsak
Feb 15, 2009 04:33 PM
boostedwagon
Nov 16, 2007 09:01 PM
Sanj
Feb 19, 2007 04:21 PM
hondachris1994
16
May 27, 2006 06:37 PM
