Knock Sensor Code
Old Jan 18, 2006 | 02:00 PM
Low-odds's Avatar
Default Knock Sensor Code
Hey i have a 90 acura integra with a b16a swap and im getting a code for my knock sensor i replaced it with another and it still is throwing the code i checked my wires and they all seam to be inplace is there anything else i should look for? i am stumped.
Old Jan 18, 2006 | 04:43 PM
SteveoBA8's Avatar
Default Re: Knock Sensor Code (Low-odds)
continuity from the ks connector to the Correct ecu Pin, make sure the threads are clean
Old Jan 19, 2006 | 06:22 AM
IHateJDM's Avatar
Default Re: Knock Sensor Code (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">continuity from the ks connector to the Correct ecu Pin, make sure the threads are clean</TD></TR></TABLE>
, and make sure its wired to the correct pinout. but this is assuming that your motor isn't pinging...
MONSTERek4
Dec 23, 2007 03:52 PM
EF_FEVER
Feb 22, 2007 12:32 PM
93sidelsolvtec
Jan 22, 2007 03:50 PM
99spanishGT
Mar 26, 2004 12:40 PM
roadawg
Feb 11, 2004 01:10 PM
