Itr swap into an 88 crx si
How can I swap an itr motor into an 88 crx si ?
I'm looking for information on what I will need to put a itr motor in my crx. I just want to put the enginge in it (not the tranny). I was wondering if I could use my pr3 (b16a) ecu along with my obd0 harness. If so, I think I will have to get the airfule ratio change, an obd0 (B16a) distributer, and I'll have to use my b16a intake manifold. Please let me know what how I can put it in with out having to rewire my intire car.
Re: How can I swap an itr motor into an 88 crx si ? (richman51385)
Yes, and it will be simple if you use your PR3 OBDO ECU, the B16A dizzy and injectors.
You can use the TYPE R manifold, just change out the injectorys.
You will also need to use the B16A side mount bracket (bracket for drivers side mount under the timing belt cover).
