OBD2 3 wire IACV to OBD1 2 wire harness Help
Old 01-10-2006, 01:47 PM
2nrz's Avatar
Default OBD2 3 wire IACV to OBD1 2 wire harness Help
This is the third time I have had this question brought up and need a solve from someone that knows what to do on it. The scenario is they swapped an obd2 engine into an obd1 accord. Everything matched after swapping dist., sensors, etc., but when they got to the IACV, the bolt pattern is different and won't go over onto it. I know that an adapter plate can be manufactured, but that is not the way that I want to go. I would like to just wire in the obd2 three wire to the two wire harness. Cut two of the wires and splice them together? Cut one of the wires and run only two of the wires on the IACV? Possible or not? I did a search and came up with nothing.
Old 01-10-2006, 03:20 PM
EE_Chris's Avatar
Default Re: OBD2 3 wire IACV to OBD1 2 wire harness Help (2nrz)
Not possible.
ECU's that originally controlled a 2-wire IACV will never contol a 3-wire IACV and vice-versa.
Old 01-17-2006, 12:58 PM
2nrz's Avatar
Thanks for the reply. Didn't know if anyone had figured this one out yet.
Old 01-17-2006, 01:12 PM
rainforest's Avatar
blah....what motor goit put in the car????
Old 11-06-2006, 07:01 AM
cornflake-dc2's Avatar
Default Re: OBD2 3 wire IACV to OBD1 2 wire harness Help (rainforest)
soo, does anyone know how to fix this problem , im swapping a b16a sir2 motor into a 96dx hatch , p28 with eric's racing chip, obd2 wiring harness spliced with b16a harness and no matter what i do i cant get the idle fixed , damn 2 wire to 3 wire
Old 11-06-2006, 05:35 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: OBD2 3 wire IACV to OBD1 2 wire harness Help (cornflake-dc2)
don't know if this helps or not
Old 11-06-2006, 06:05 PM
marshun's Avatar
Default Re: OBD2 3 wire IACV to OBD1 2 wire harness Help (HondaPartsHero)
ohh i had a time with that one on my h22 96 ek. apparenlty the wires on the ecu side are pinned different between some years? or maybe from different manufactureuers. anyway the wires on the ecu side werent where they were supposed to be. like displayed in that pic^
i just repinned them and it was all good.
gotta have the FLUKE for bigger wiring jobs.
Old 01-21-2008, 08:11 PM
Honda_Fanatic's Avatar
NICE Thread! Thanks
shahriar35
01-14-2012 01:09 PM
EfSedanLove
04-02-2008 10:54 AM
keaps206
10-12-2005 06:15 PM
b20_vtec_integra
12-02-2004 04:39 PM
junglerunna
04-10-2003 04:11 AM
Quick Reply: OBD2 3 wire IACV to OBD1 2 wire harness Help
