swap is complete, trouble starting....
Old 01-04-2006, 12:41 PM
Rxmig7's Avatar
Default swap is complete, trouble starting....
I am finally done with my LS swap into my 92 EG. Before I tell my problem here is what I have on the car. 93 LS block (stock) with its wiring harness, 94 gsr transmission with act clutch. The problem is the motor doesn't start up. It's getting fuel and spark because it backfires ever now and then. Any help is appreciated.
Thank you very much.
Miguel V.
Old 01-04-2006, 02:01 PM
IHateJDM's Avatar
Default Re: swap is complete, trouble starting.... (Rxmig7)
so you have fuel and spark, now check for timing and compression.
Old 01-04-2006, 03:06 PM
Slopoke's Avatar
Have you actually checked for spark, or are you just assuming because its backfiring every once in a while.
Pull a plug and make sure your getting spark.
Then Check your timing marks. Also check your plug wires to make sure they are in the correct order.
Lastly, check compression.
Old 01-04-2006, 10:52 PM
ek99's Avatar
Default Re: (Slopoke)
Check your firing order, its probably off. 1-2-4-3
Old 01-05-2006, 06:10 PM
Rxmig7's Avatar
Default Re: (ek99)
could it be the plug(s) that go on the clutch pedal???
Old 01-05-2006, 07:20 PM
Slopoke's Avatar
Default Re: (Rxmig7)
lol, what?
Old 01-05-2006, 11:28 PM
ek99's Avatar
If there was something wrong with those switches then your car would not even crank.
Old 01-07-2006, 02:39 PM
Rxmig7's Avatar
Default Re: (ek99)
Thanks for your help, i'm going to check if each plug is getting spark....I fixed my timing belt it was a bit loose yesterday and it's tight now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 &raquo;</TD></TR><TR><TD CLASS="quote">Check your firing order, its probably off. 1-2-4-3 </TD></TR></TABLE>
Are you sure that's the firing order for a b18a1?
Thank you all, I will keep you posted.
Old 01-07-2006, 04:16 PM
Slopoke's Avatar
Firing order is 1,3,4,2.
Old 01-07-2006, 05:58 PM
Rxmig7's Avatar
with the firing order 1-2-4-3 it tried to crank up but i've noticed that cylinder 1,2,and 3 is not getting any fuel. Only #4 is..... I will try firing order 1,3,4,2 now.
Thanks again.
Old 01-07-2006, 07:26 PM
Rxmig7's Avatar
I have also noticed my Throttle positioning sensor was not connected and broken. There is only 2 contacts for a connector. The other looks like it broke off or maybe it comes like that, not too sure. I am still only getting fuel for cylinder #4. None of the others are getting fuel. #4 spark plug is black and 1,2, and 3 are still new. All plugs are getting spark. All injectors are getting ground and power.
All help is appreciated.
Old 01-08-2006, 10:18 AM
Rxmig7's Avatar
Still not getting fuel on cylinders 1,2, and 3...
Old 01-09-2006, 09:31 AM
s_18's Avatar
Might the injectors for 1-3 be clogged?
Old 01-09-2006, 12:13 PM
Rxmig7's Avatar
Default Re: (s_18)
Since I only have 1 operating injector, I am going to put injector #4 on cylinder #1,2, and 3. Hopefully that's the problem.
Thanks again.
Old 01-10-2006, 09:27 AM
Rxmig7's Avatar
S-18, and everyone else thanks for your help. I switched the injectors yesterday and the motor came to life. Now to add all fluids and let it idle for about 20 minutes to get all the crap out of the motor.
thanks again!
sleet_22
12-09-2013 02:09 PM
'91teg
12-01-2008 09:02 PM
tarheelsoldier
03-15-2007 08:46 AM
Race Egr
04-04-2004 09:32 AM
g2turbo
09-17-2003 08:31 PM
Quick Reply: swap is complete, trouble starting....
