OBD 1 to OBD 2 or 3 not sure... HELP please this is the only thing holding me up.
i have an obd1 '95 civic that i am putting a 2001 integra Ls engine in. i want to use the ECU that came with the integra engine and the engine harness but use my iterior civic harness. can i do that and what do i need to make this work. i have posted twice now and i really need help. thanks in advance
Modified by carma42 at 9:12 PM 1/16/2006
Re: (v4lu3s)
so if i get an LS '94-'95 ecu that will be my cure? no adapters no injectors or distributor problems thats it just swap the ecu to an old LS one? everything will plug into my existing interior civic plugs on that ecu and the engine harness for the '01 LS engine will basically plug into my shock tower civic harness.? sorry to be so detailed but i have had way to many options given to me lately and this is the only thing holding me up. thanks by the way.
obd1 plugs are all teh same for civics and tegs. i dont know if the engine harness will plug into the civic chassis harness, i never do swaps that way i always use the original enging harness since i know that one will fit the car for sure.
