ls mounts b16 motor(need a quick answer plz)
hey im having a lil trouble using my ls driver side mount on my b16a2. b16a2 has two screws but the mount has 3 holes. could some one help me out real quick
Re: ls mounts b16 motor(need a quick answer plz) (v-tec maz)
i believe the b16a2 is out of the em1.. correct me if im wrong, but ls motors use the 3 bolt pattern mount on the drivers side that is round looking, while the b16a2 motor use a mount that is shaped like a bottle with two bolts...if ur gonna put this in a 92-95 civic or 94-00 integra perhaps u can swap over the timing cover post mounts from the ls onto the b16 and use the round 3 bolt mount .. but if ur gonna put it in a 96 and up civic ur going to have to buy the 2 bolt mount
Re: ls mounts b16 motor(need a quick answer plz) (wob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wob »</TD></TR><TR><TD CLASS="quote">i might have one i can send u if u pay shipping, ill go check</TD></TR></TABLE>
just pmed you.,im waiting on them to put my motor in
The mount your looking for is from a 94-01 Acura Integra GSR/Type-R timimg belt bracket. This will bolt to your block and bolts direct to your driver side mount. Hope this helps, you could also buy the part from Acura as well.
