consequences for shift cable placement
Old Jan 15, 2006 | 03:43 PM
makelove2hondas's Avatar
Default consequences for shift cable placement
h22a in a EG, what are, if there are any consequences to running the cables below the subframe? thanks
Old Jan 15, 2006 | 04:21 PM
Evil-EK's Avatar
Default Re: consequences for shift cable placement (makelove2hondas)
not really any problems as long as you get the cables good and tight. Dont let them hand down near the exhaust and such. If I were you I would run them over the crossmember. Just keep in mind once you cut the holes in the floor there is not much room for changing your mind.
Old Jan 16, 2006 | 06:34 AM
IHateJDM's Avatar
Default Re: consequences for shift cable placement (BigBlockH22atch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch &raquo;</TD></TR><TR><TD CLASS="quote"> If I were you I would run them over the crossmember. Just keep in mind once you cut the holes in the floor there is not much room for changing your mind.</TD></TR></TABLE>
i've had cables break on me since they were stretched too tight.
dansaleen_04
Oct 6, 2010 02:36 PM
freshvibes
14
Jan 15, 2008 08:59 PM
FernEF
Feb 13, 2006 07:42 PM
youngwon22
May 2, 2004 10:55 AM
.cingham
Nov 3, 2003 04:54 PM
