does the obx lsd have an washer type in the middle where the axle goes???not a stright hole like itr
looking at the obx lsd and notice there is a washer type when looking inside the axle hole. is this how obx lsd look like? i notice itr's lsd have a stright hole all the way through.
Re: does the obx lsd have an washer type in the middle where the axle goes???not a stright hole like
You should be able to see all the way through it, but there are washers in there. The area you will be able to see through should be about 1/4" diameter.
Those washers are called Belleville washers (type of spring washer) and preload the gears inside the diff.
