Broken Bolts!!!!
Old Jan 16, 2006 | 03:57 PM
b18c inside's Avatar
Default Broken Bolts!!!!
I recently replaced my cam seal and was putting everything back together. I managed to over torque 3 bolts and break them off. Two were on the camshaft cover plate. The final one isn't snapped completely in half but very close. How can I go about getting the broken part out of there? Please someone help me out. Thanks!!!
Old Jan 16, 2006 | 06:41 PM
Goinfasterthanu's Avatar
go to sears and get a easy out....
Old Jan 27, 2006 | 05:55 PM
Default Re: Broken Bolts!!!! (B18C inside)
bump
Old Jan 27, 2006 | 06:01 PM
TurboLaxx's Avatar
you should have stopped building the head yourself when you broke the first bolt. Then you would only have 1 broken bolt. Get an easyout.
Old Jan 27, 2006 | 06:59 PM
runeminaEF9's Avatar
Default Re: (TurboLaxx)
damn, you really really wanted to make sure they wouldnt come loose, i guess. so, after the first one snapped, what motivated you to tighten the others down just as much???
Old Jan 27, 2006 | 07:05 PM
dwnthehatch's Avatar
Default Re: (runeminaEF9)
https://honda-tech.com/zerothread?id=567450
Old Jan 28, 2006 | 11:29 AM
hapexamendios 2.0's Avatar
R.I.P.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runeminaEF9 &raquo;</TD></TR><TR><TD CLASS="quote">damn, you really really wanted to make sure they wouldnt come loose, i guess. so, after the first one snapped, what motivated you to tighten the others down just as much???</TD></TR></TABLE>no ****
Old Jan 29, 2006 | 09:25 AM
I was told the wrong torque specs...oh well.
Old Jan 29, 2006 | 10:35 AM
rudebwoy's Avatar
I did the same, I broke 2 of the camshaft holder plate bolts from the exhaust cam, and while I was trying to extract them with a easy out, the easy out cracked my cam cradle, so I am punning my car with a piece missing from my exhaust cam cradle and 2 broken bolts
invisible
58
Apr 11, 2007 08:54 AM
RACEPAK
Sep 3, 2005 10:14 AM
lv6l
Nov 24, 2004 07:30 AM
sacredc0w69
Apr 13, 2004 08:50 PM
syndicate43
Nov 25, 2002 05:49 PM
