LSV converstion questions?
LSVTEC converstion questions?
I need Vtec Solenoid for my LSVtec conversion... Where can i find one online? Does it come with the Distributor? Im thinkin about getting a OBD1 GSR Distributor from StreetImport .com ... Im just tryin to piece together my vtec head.
Another question is could i run GSR axles with my Hydro LS tranny in my Hatch?
would it work? what do i need to do?
As for ECU im runing the LS and planing to look for a P72 ECU obd1 gsr but its seem to be to much so what is my other options? do i need a harness too?
I hope u guys could help me thanks for your time.
Modified by 93DXEGG at 8:59 PM 1/2/2006
Re: LSVTEC converstion questions? (Phatch99)
i got a 98 gsr vtec head.
im going to keep it obd1.
i have a ge lsvtec kit.
-usdm ITR pistons & rings
-arp head bolts/ rods bolts
-gsr water pump and t belt
what i need ...
-vtec solenoid
-distributor GSR obd1
-GSR ecu / not sure about harness if i need that too..
-axles
what else do i need.? im keep my ls tranny for now .. hopefully after tax season i could find a good gsr tranny along with lsd or itr tranny... hope that helps... let me know i theres other things i might need.
what i need ...
-vtec solenoid
-axles
Re: LSVTEC converstion questions? (93DXEGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DXEGG »</TD></TR><TR><TD CLASS="quote">I need Vtec Solenoid for my LSVtec conversion... Where can i find one online? Does it come with the Distributor? Im thinkin about getting a OBD1 GSR Distributor from StreetImport .com ... Im just tryin to piece together my vtec head.
The vtec solenoid and distirbutor and two completely different things. They dont come together.
I'd look through the h-t classifieds or on ebay for either.
Yes you can run gsr axles with your LS tranny. They are no different.
Find an obd1 GSR ecu. Dont waste your time swapping harnesses, since even with a GSR engine harness, you'll still have to run wires from the shock tower plugs, down to the ecu.
You can reuse your ls harness. Simply add the neccessary wires for vtec solenoid, vtec oil pressure switch, knock sensor, and IABs.
Then your set.
Then your set.
