b16a2 in 97gsr (need help quick, restoring process)
hey everyone, im doing a gsr restoration. i have a b16a2 with a cut harness, and my shell has the harness cut at the same place. can i just use clips and connect them togheter. since they are both obd2. also if i get a new harness, should i get a gsrobd2 or for the si? one more question. can i use the b16a2 ecu that i have or i have to get a gsr ecu? plz help me out cause i wanna get this running asap.
thank you
thank you
Re: b16a2 in 97gsr (v-tec maz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-tec maz »</TD></TR><TR><TD CLASS="quote">hey everyone, im doing a gsr restoration. i have a b16a2 with a cut harness, and my shell has the harness cut at the same place. can i just use clips and connect them togheter. since they are both obd2. also if i get a new harness, should i get a gsrobd2 or for the si? one more question. can i use the b16a2 ecu that i have or i have to get a gsr ecu? plz help me out cause i wanna get this running asap.
thank you </TD></TR></TABLE>
1. no
2. gsr obd2a
3. no, you need a p30 obd2a (96-99)
Modified by pennies_hatchie at 8:44 PM 12/31/2005
1. no
2. gsr obd2a
Re: b16a2 in 97gsr (pennies_hatchie)
1- is it unsafe or is it just impossible?
2- isnt that the same as the on ethat is in the car? its a 97 gsr?
3- wtf? bad luck
3- wtf? bad luck
Vapochilled
09-16-2008 01:39 PM
Vapochilled
09-16-2008 09:09 AM
