'92 hatch swap
Old Jan 16, 2006 | 01:50 PM
bikemulisha's Avatar
Default '92 hatch swap
i have a 92 hatch cx bone stock and just purchased a b18a1 and im wondering if this will bolt right up or will i have to convert ne thing thanks!
Old Jan 16, 2006 | 01:51 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: '92 hatch swap (bikemulisha)
Put your flamesuit on! Here borrow mine!
Old Jan 16, 2006 | 01:54 PM
HATCHingMN's Avatar
you need motor mounts,axles, and shiftlinkage from the 94+ integras,..
get the proper ecu to run that b18
then everything will be plug and play
Old Jan 16, 2006 | 01:55 PM
3rd g3aR vTak
WOW! Nobody told you to "search" yet! You got lucky!
Old Jan 16, 2006 | 02:13 PM
HATCHingMN's Avatar
be nice to noob
Old Jan 16, 2006 | 02:15 PM
the motor is a 91 out of an integra ls w/ bout 230k miles
Old Jan 16, 2006 | 02:18 PM
Spracer03's Avatar
have you done a compression test on it yet? i dont think youd wanna waste your time swapping a worn out non-vtec motor/engine
Old Jan 16, 2006 | 02:35 PM
Default Re: (spracer03)
motor ran great when removed.i plan gettin forged rods and pistons 4 it. should i have it pressure checked and honed or what. i want it to last. i also hear that i will need tranny obd1 ecu and harness, axels and mounts is there ne thing else. and iim thinkin a brake and suspension upgrade would be good.
Old Jan 16, 2006 | 02:49 PM
Hybrid96EK's Avatar
Default Re: (bikemulisha)
I'm thinking it would be best to hold on until you have something really worth the time to swap in. That motor is only 130hp. At least upgrade the intake manifold and cams so its = to the 140hp version.
Old Jan 16, 2006 | 02:56 PM
Stoich EG2's Avatar
you need a hydraulic transmission y0
edit: my spelling sux
Old Jan 16, 2006 | 03:00 PM
redhondacivic's Avatar
Default Re: '92 hatch swap (HATCHingMN)
I've been told that you can use the linkage from a 90-93 integra and it locates the shifter 1" closer to the firewall. Not positive, please correct me if I'm wrong.
Old Jan 16, 2006 | 03:05 PM
Default Re: '92 hatch swap (redhondacivic)
i have a 93 hatch that was totaled it has a b18b1 with a cracked head and the motor mounts have been ripped out dont know if cams have been damaged. could i use the tranny, ecu, harness, cams if good, distributor and intake manafold off of it?
Old Jan 16, 2006 | 03:54 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhondacivic &raquo;</TD></TR><TR><TD CLASS="quote">I've been told that you can use the linkage from a 90-93 integra and it locates the shifter 1" closer to the firewall. Not positive, please correct me if I'm wrong.</TD></TR></TABLE>
How does that make any sense? No, its not going to locate the shifter closer to the firewall.
Old Jan 16, 2006 | 03:55 PM
JCritt's Avatar
Default Re: '92 hatch swap (Hybrid93Eg)
search
mikehinkle
29
Jan 31, 2014 07:30 PM
VtecCustums
Oct 19, 2008 08:01 PM
4-ageTOg63
12
May 26, 2004 12:48 PM
