True LS VTEC
Old Jan 18, 2006 | 11:16 AM
MessGSR's Avatar
Default True LS VTEC
From what i learned, a ture ls vtec is ls internals in a vtec bottom end. i am putting ls internals into a b16a1 bottom end, with my choice of pistons, my question will i have a problem with clearence with the b16 having a shorter deck height then say the ls blcok if i were to run jdm b16 psiton or even itr pistions thanks
Old Jan 18, 2006 | 12:00 PM
MrMike's Avatar
Default Re: True LS VTEC (MessGSR)
no matter what pistons you use they will stick out of the deck in a B16 block. A truel LSVTEC is LS internals in a B18c block.
Old Jan 18, 2006 | 08:05 PM
StorminMatt's Avatar
Default Re: True LS VTEC (MrMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrMike &raquo;</TD></TR><TR><TD CLASS="quote">A truel LSVTEC is LS internals in a B18c block.</TD></TR></TABLE>
I guess a 'true' LS-VTEC is what you want it to be. But as far as I am concerned, a true LS-VTEC uses an LS block. After all, that was the whole original idea of the concept - to build a 1.8 liter VTEC motor without the expense of any P72 parts. If you put it in a P72 block, then you just have a GSR/ITR/Poor man's ITR running an LS crank.
Old Jan 18, 2006 | 08:32 PM
MessGSR's Avatar
Default Re: True LS VTEC (StorminMatt)
yea it might be a poor, but its ture ls vtec, but a ls rod and crank combo will give u like 1.899.... displacement, where as the a gsr, and type-r is only 1.7..., and a b16 is 1.5..... correct me if i am wrong but its as close to a 2 liter, without a new block, and has the ability to rev to 8000 82000. but just my out look or opinion
Old Jan 18, 2006 | 09:40 PM
Nuke209's Avatar
b16 is 1.6
b18 is 1.8
notice the 16 and the 18
Old Jan 19, 2006 | 05:21 AM
B16A = 1595cc
B18A/B18B/LS-VTEC = 1834cc
B18C = 1797cc
B20B/B20Z = 1972cc.
Old Jan 19, 2006 | 11:40 AM
MessGSR's Avatar
what i am really concerned with now is can i run the ls internals in the b16 bottomend with out problems, or should i find a gsr block?
92hondaswap
Jun 26, 2008 02:43 PM
limpy
Jul 14, 2005 01:40 PM
whiteknightef
Mar 30, 2004 10:00 AM
Kingsperformance
Feb 25, 2004 02:16 PM
EvilIntegrationLS
Apr 19, 2003 05:24 PM
