Engine rebuild prices? Overcharged-Average-Cheap
I'm getting my h22a in my ek rebuilt for my turbo setup. Here's the prices the shop is giving me. What you should I do pay or else where.
Sleeves $700.00 including machine work
JE Piston $475.00
Eagle Rods $325.00
Bearings $160.00
head studs $110.00
Head gasket $100.00
Ferrea Valves $230.00
Valve seals $75.00
Walbro Fuel pump $110.00
Labor/Motor build $1000.00
machine work $350.00
Turbo install/Street tune $500.00
JE Piston $475.00
Eagle Rods $325.00
Bearings $160.00
head studs $110.00
Head gasket $100.00
Valve seals $75.00
seems pretty reasonable, the shop i manage for labor alone on a rebuild would charge about $1300-1400 if we had to R&R the engine, probably around $1000 if we did not have to rmeove and install the engine.
Re: Engine rebuild prices? Overcharged-Average-Cheap (Vintech)
Allaboutspeed motorsports gave me that estiment. I only had the swap in my car for about 3 weeks. Oil light kept on flash after a oil change. figure it wasn't nothing big. Second day driving, oil light stayed on. Got it check out, turns out oil pick up was crap. Ate up all the bearings particles were in my pan. I figure if they were going to rip it up. Then I mine as will get it built now for turbo. Should of did it before, but thats my fault.
Re: Engine rebuild prices? Overcharged-Average-Cheap (UPYOURZ)
Oh if you wondering where the hell they are located. There on 1104 Columbia Ave South Milwaukee.
I would go to all about speed Donny knows what he's doing. And he's not a ******* he helped me out when I was having trouble with my swap. The only thing is he takes a little longer than others sometimes.
what kind of bearings are you getting...acl's usually go for about 90-100 only...but 160 seems good for oem bearings...valve seals should only be about 30-40 bucks or so...but everything else seems right.
Yeah I think its for all my bearing. I think oem, but yeah donny's okay. Took him like 7 months to do my h22 swap. I guess thats normal if you say so. He's the only choice I have for now, thats why i'm there.
EG-SIXV-TEC
05-10-2012 06:48 PM
RedEj8
12
04-26-2006 03:33 PM
