How to make Custom Axles
Old Jan 2, 2006 | 06:53 AM
2point2's Avatar
Default How to make Custom Axles
- get a pair of worn out axles and cut them in half
- take the cv's and cups apart and clean all the grease out of them, a parts washing bin will clean them up very nicely.
- put the car on it's wheels @ driving/racing height. (full weight and compressed suspension) - It's easiest on a drive on hoist but you can do it on a two post hoist if you are creative. The main objective is to put the suspension exactly where it will be as the car is driving.
- install the axle halves back in without the boots - this is tricky, take your time!! You'll need a hand because the cv's will fall out of the inner cups very easily without boots holding them together.
Now you have to determine where you want the inner CV's to be while the car is in motion. To do this, Bottom out the inner half of the axle pushing towards the tranny and then pull it back towards you about .75" to 1.25" (these measurements are off the top of my head, use your best judgment).
The inner cup of the axle is designed to allow the CV's to slide in and out along the axles axis (you'll see what I mean if you didn't already know). As the steering wheel turns and the suspension compresses and decompresses the axles slides within the inner(tranny) cup.
Now that you have established where you want the inner CV to be you can now determine how long you need to make the axle shaft. Pictured below is how to mock up a shorter axle. A piece of pipe is used to keep the two halves of the dummy axle fairly concentric. A few good tacks will keep your mock up assembly together.
At this point you have a complete <FONT SIZE="5"><u>*mockup*</u></FONT> of your axles. Triple check that the axles work under all suspension and steering situations by raising and lowering the car and steering in booth directions.
<FONT SIZE="5">do not be an idiot and attempt to drive the car on welded axles.</FONT> All you have left to do is remove your mockup axles, dissemble them, and bring mockup axle shafts to a good machine shop that can cut splines.
comments/questions welcome, I will revise/edit as needed.
Modified by 2point2 at 9:32 AM 3/23/2006
Modified by 2point2 at 9:35 AM 3/23/2006
Old Jan 2, 2006 | 01:44 PM
delspool's Avatar
Default Re: How to make Custom Axles (2point2)
good info, a good writeup always helps
Old Jan 2, 2006 | 10:28 PM
hondaZvic's Avatar
Default Re: How to make Custom Axles (delspool)
not a bad idea man
that is definetely alot better then spending money on different ones hoping to get the right setup...
Old Jan 3, 2006 | 03:37 AM
2point2's Avatar
Default Re: How to make Custom Axles (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">not a bad idea man
that is definetely alot better then spending money on different ones hoping to get the right setup...</TD></TR></TABLE>
I agree.. plus you can choose what metal you want to use when you have the axle shafts machined.. i beleive mine are 4130.
Old Jan 3, 2006 | 05:23 AM
RotiEatter's Avatar
Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
do not be an idiot and attempt to drive the car on welded axles. </TD></TR></TABLE>
Yeah...
so I went through your post and followed it step-by-step... but then I put them on and drove around before I read this part. You owe me $1,500 for a new tranny and axles.
Nice write-up homie, like Zane said.. beats guessing
Old Jan 3, 2006 | 11:04 AM
skunked's Avatar
Default Re: How to make Custom Axles (RotiEatter)
Nice
Old Jan 3, 2006 | 11:07 AM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">
like Zane said.. beats guessing </TD></TR></TABLE>
tats bcuz i shmart mayne
Old Jan 3, 2006 | 01:24 PM
Jonathan_ED3's Avatar
Exactly what I've been looking for
Old Jan 3, 2006 | 02:10 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">You owe me $1,500 for a new tranny and axles. </TD></TR></TABLE>
"Cheque" is in the mail. It comes out to $1.45 USD.
Old Jan 4, 2006 | 03:58 PM
EJtypeR's Avatar
what about vibration? arent axles balanced?
Old Jan 4, 2006 | 07:28 PM
Where would vibration be introduced at?
After you make the mock-up, you're supposed to get a new one made.
You're not supposed to use the ones that are welded together.
Old Jan 5, 2006 | 03:45 PM
EJtypeR's Avatar
Default Re: (Jonathan_ED3)
oh got you its just a mock up. i thought you where running the axles like that...haha
Old Jan 9, 2006 | 08:02 AM
happyb16xrc's Avatar
Default Re: (EJtypeR)
Yeah...
Nice write-up homie, like Zane said.. beats guessing </TD></TR></TABLE>
i hope that is a JOKE but if not lol thats is some funny ****
who remakes axels?
Old Jan 9, 2006 | 08:08 AM
skunked's Avatar
Default Re: (happyb16xrc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happyb16xrc &raquo;</TD></TR><TR><TD CLASS="quote">
who remakes axels?</TD></TR></TABLE>
yeah, he is just mess'n around.
Old Jan 9, 2006 | 08:20 AM
Turbogixxer's Avatar
Default Re: (skunked)
Great write up
Old Jan 11, 2006 | 05:40 AM
RACEPAK's Avatar
Default Re: How to make Custom Axles (skunked)
keepitngga1
Dec 21, 2006 05:00 PM
Death_to_Thieves
Aug 24, 2004 09:39 PM
LostAndFound
Jun 13, 2004 01:48 PM
Tweakmeister
Nov 5, 2003 04:51 PM
type Gendy
Jan 19, 2003 06:18 PM
