auto 97 dx -swapin in manual gsr obd1?
hey whats up guys! ive searched and could not find exact info on this swap i pretty much got it figured but still have some question, any info will be appriciated!
i got a 97 dx auto and i might be throwin in a obd1 gsr swap
first- im goning to convert from auto to manual.
i know i need the clutch pedal assy, master cyl, and clutch line.
then have to trick the ecu into thinking its in park, wire up reverse lights.
now about the swap its a 95 gsr swap
i know i need mounts and back bracket from 99si correct?
do i need any brackets do to this being a auto chassis , i think only the eg's need one right?
wiring?
i can use a engine harnness out of a 96-98 ex correct?
an obd2a to obd1 ecu jumper, obd1 ecu
now do i need to run additional wires directly to the ecu like for vtec and etc?
i know the obd1 dist can be rewired for the obd2 harness, can the altinator plug be rewired as well?
any other little things that i might irun into during the swap that i should know about?
wiring?
screen_name
Engine Management and Tuning
06-11-2010 11:47 PM
ComputerJLT
02-07-2005 09:32 AM
