I got a VTEC issue!!
Old Jan 11, 2006 | 01:23 AM
robin_yanani's Avatar
Default I got a VTEC issue!!
I got a B18C (type R) motor in my 92 si hatch and I having vtec issues, motor is brand new less then 20k miles. When I hit my vtec range which is at 5800 my vtec will work but sometimes engage and disengage kind of like as if where simotaniously turning on,off,on/vtec,pause,vtec you get the picture.. I was thinking more like a ECU problem or dirty vtec solonoid/bad grounding/poor(low)oil lvls... Can I have some of you peeps output??
Old Jan 11, 2006 | 06:12 AM
IHateJDM's Avatar
Default Re: I got a VTEC issue!! (robin_yanani)
how is your oil level? where is your pressure switch ground connected at, and what ecu?
Old Jan 11, 2006 | 06:15 AM
mountainEG6's Avatar
Like you said I would start out checking the oil. If it doesn't seam to be that then check your VTEC solenoid. Do you have an aftermarket or flashed ecu?
Old Jan 11, 2006 | 06:16 AM
v4lu3s's Avatar
RTFM
also check your distributor as well.
Old Jan 11, 2006 | 06:33 AM
ALMXDUPINTEGRA's Avatar
Oil pressure
Old Jan 11, 2006 | 06:33 PM
daveedd357's Avatar
make sure that your oil pan isnt dented. will hender your oil flo and pressure
Old Jan 12, 2006 | 01:38 AM
Default Re: I got a VTEC issue!! (daveedd357)
Thanx guys the poblem was that my ECU was bad changed to a chipped OBD2 p73 and yes you can chip the OBD2 ECUs had a friend do it for me but car runs perfect now was stressin out but thnx for all your guys help
crxfreak1117
Feb 26, 2010 06:47 AM
93eghb
Jan 20, 2009 12:07 AM
Stephdavis18
Jan 20, 2007 11:55 PM
Jagolas
10
Aug 8, 2004 02:33 PM
roninb18
Jan 17, 2003 06:54 AM
