WILL A SOHC BLOCK MOUNT FIT B SERIES
My question more specifically is whether or not a d16z6 block mount, the cast piece, not the fluid filled part, but the part that actually bolts to the block, will fit on a obd1 gsr block correctly? I was told that it would.
Re: WILL A SOHC BLOCK MOUNT FIT B SERIES (rainforest)
Does that mean no?? anybody care to elaborate? I was told by a friend taht he thinks he was able to use one before. he took it of of the single cam he took out and swaped it over to the b16 that he put in. The one on my b18c is bent believe it or not. So i wanted to know if it works or not?
Re: WILL A SOHC BLOCK MOUNT FIT B SERIES (BoRiCuA)
From what I recall sohc block mounts have two holes in them and dohc mounts have three. I remember them being different.
Re: WILL A SOHC BLOCK MOUNT FIT B SERIES (mattssi)
if your talking about the cast braket that goes on the timing belt side no pm pe i have one with the bolts
Modified by robspec at 2:51 AM 3/8/2006
92EG8
07-04-2007 07:35 PM
stickyfingers
13
02-08-2005 04:50 PM
