fuel systems
Old Jan 18, 2006 | 01:35 PM
Adam West's Avatar
Default fuel systems
Is it neccessary to change all the fuels lines even the one from the fuel pump to the fuel filter when lookin for more fuel delivery????? how many lph are stock honda fuel lines good for???? thisis for a h swap
Old Jan 18, 2006 | 01:37 PM
IHateJDM's Avatar
Default Re: fuel systems (Oclooc)
i don't know how many lph they are good for, but they can handle a lot more than a stock H.
Old Jan 18, 2006 | 01:41 PM
Adam West's Avatar
Default Re: fuel systems (IHateJDM)
so I wouldnt have to change the lines under thecar to the fp then right????
Old Jan 18, 2006 | 01:44 PM
IHateJDM's Avatar
nope, i know from experience that you can run rich as hell with an H22 on those stock lines.
Old Jan 18, 2006 | 01:50 PM
Adam West's Avatar
thank you sir help is greatly appreciated... reason I asked is cause I was ready a build up and they mentione stock fuel systems need to be upgraded completly when more fuel delivery is needed... I guess I will stick with a fuel filter and red lines to dress it up....
Old Jan 18, 2006 | 01:58 PM
IHateJDM's Avatar
right now i'm running a stock civic dx fuel pump, stock lines, inline fuel filter (fittings didn't match up during my swap since whoever pulled the motor cut the line from the fuel rail to the filter), stock H fuel rail, and 345 cc stock injectors. The only aftermarket piece I have on my fuel system is a b&m fpr, which I did need to crank up the fuel pressure about 10 psi to get to 40 at wot. If anything I'm running slightly rich right now, but the motor runs well.
Old Jan 18, 2006 | 02:06 PM
Adam West's Avatar
and u would crank the pressure from the regulator right???????
Old Jan 18, 2006 | 02:11 PM
IHateJDM's Avatar
yeah, the b&m fuel pressure regulator is designed to replace half of the stock unit. it really just gives it a stiffer spring and the ability to raise your fuel pressure. the stock fuel pump only gave me about 29 psi of pressure at wot (make sure you pull the vacuum line off the fpr to simulate wot), so I had to crank it up to around 40. 4th gen h22's (345cc injectors) are supposed to have 35-42 psi @ wot and 5th gen motors (290 cc injectors) should run 45-50 psi.
Old Jan 18, 2006 | 02:29 PM
skunked's Avatar
unless you have a motor that demands allot of fuel there is no need to replace the factory hardlines. Aftermarket fuel pump, FPR and injectors are a more common upgrade/requirement.
Old Jan 18, 2006 | 03:03 PM
Adam West's Avatar
Default Re: fuel systems (skunked)
ok so I should just get a fpr (in case) a good filter and a fuel rail???? I already have a walboro fuel pump
Old Jan 18, 2006 | 03:06 PM
skunked's Avatar
the rail won't do **** for ya. If you get a new fpr make sure you get a fuel psi gauge so you can make sure its set after the install. Fuel filters can get clogged easily from bad fuel or particles in your tank so I would suggest changing them often.
Old Jan 18, 2006 | 03:14 PM
Adam West's Avatar
perfecto. I was just looking for an excuse to buy ****.... I guess Im good with what I have.. only thing I have to do now is get the right fittings for the filter....
GreeceS13
Jul 21, 2015 04:01 AM
RoadRaceMike
May 10, 2011 12:38 PM
b20vcrxsir
Apr 21, 2009 09:01 AM
boomslang
Dec 5, 2002 10:36 AM
dustin
Oct 2, 2001 04:23 PM
