FAQ: Common swap problem AND general troubleshooting!
Old Jan 5, 2006 | 05:36 PM
Turbogixxer's Avatar
Default FAQ: Common swap problem AND general troubleshooting!
Modified by Turbogixxer at 12:08 PM 4/1/2007
Old Jan 5, 2006 | 09:00 PM
8200RPM's Avatar
local hippie
Default Re: FAQ: Common swap problem AND general troubleshooting! (Turbogixxer)
dude, I just read everything... and its all wrong...
jk
good stuff, subscribed
Old Jan 6, 2006 | 09:39 AM
92acclude's Avatar
Default Re: FAQ: Common swap problem AND general troubleshooting! (5th gen ludette)
Dear god, thank you.
Old Jan 7, 2006 | 08:24 AM
RACEPAK's Avatar
Default Re: FAQ: Common swap problem AND general troubleshooting! (92acclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92acclude &raquo;</TD></TR><TR><TD CLASS="quote">Dear god, thank you.</TD></TR></TABLE>
Old Jan 7, 2006 | 12:03 PM
lak8's Avatar
Nice right up Turbogixxer - this guy knows what hes talking about. helped me out a couple times
Old Jan 8, 2006 | 06:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lak8 &raquo;</TD></TR><TR><TD CLASS="quote">Nice right up Turbogixxer - this guy knows what hes talking about. helped me out a couple times</TD></TR></TABLE>
Thanks, I will try to add more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5th gen ludette &raquo;</TD></TR><TR><TD CLASS="quote">dude, I just read everything... and its all wrong...
jk </TD></TR></TABLE>
Old Jan 21, 2006 | 07:45 PM
YeeJ6's Avatar
good stuff
Old Jan 26, 2006 | 02:13 PM
skunked's Avatar
Default Re: FAQ: Common swap problem AND general troubleshooting! (spoonspeed)
great info here
good answers for the commonly asked questions.
Old Jan 26, 2006 | 03:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonspeed &raquo;</TD></TR><TR><TD CLASS="quote"> good stuff</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">great info here
good answers for the commonly asked questions.</TD></TR></TABLE>
Thanks
Add some info
Old Feb 24, 2006 | 08:56 AM
h22aseemsgood's Avatar
kenny its brandon give me call when u get a chyance bro at 860-796-9173 there is something wrong with my h22a i think, plus just this last week i ordred a brand new an-r header, BS!@!! give me call bro when u get a chance.
Old Apr 18, 2006 | 07:18 PM
ProJectCvic's Avatar
Default Re: FAQ: Common swap problem AND general troubleshooting! (h22aseemsgood)
This is an excellent writeup man Thanks for taking the time.
Old Apr 19, 2006 | 10:58 AM
hondaZvic's Avatar
Default Re: FAQ: Common swap problem AND general troubleshooting! (ProJectCvic)
****... i never saw this..
good info Kenny!!!!!
need to sticky this one, and add more.
Old Apr 21, 2006 | 03:30 PM
SiRTifiedacc's Avatar
Default Re: FAQ: Common swap problem AND general troubleshooting! (hondaZvic)
hey i got an issue.. haha..eversince since i did my h22 integra swap.. my speedo never worked.. i've swapped out the VSS and that didnt work... i do recall, when i first did the swap... i remember sitting in the parking lot after i cranked the car up.. and the speedo jumped to about 120 mph for about 20 secs.. (all while im just sitting idle in the driveway).. then it dropped and never worked again.. (the only thing i can think of is that i burned up the wiring to it.. i've swapped ecu's and all.. no luck
Old Apr 22, 2006 | 05:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">This is an excellent writeup man Thanks for taking the time.</TD></TR></TABLE>
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic &raquo;</TD></TR><TR><TD CLASS="quote">****... i never saw this..
need to sticky this one, and add more.</TD></TR></TABLE>
Add more, pfft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRTifiedacc &raquo;</TD></TR><TR><TD CLASS="quote">hey i got an issue.. haha..eversince since i did my h22 integra swap.. my speedo never worked.. i've swapped out the VSS and that didnt work... i do recall, when i first did the swap... i remember sitting in the parking lot after i cranked the car up.. and the speedo jumped to about 120 mph for about 20 secs.. (all while im just sitting idle in the driveway).. then it dropped and never worked again.. (the only thing i can think of is that i burned up the wiring to it.. i've swapped ecu's and all.. no luck</TD></TR></TABLE>
The VSS gets a 12v switched power, ground and signal to the ECU. The vss pulses the 12v in a square pattern. First, check the connector to see if it is seating all the way. If it is not, you will have this problem. It is a common problem.
Then check if you are getting the 12v swtiched and ground, and se what you get
Old Apr 22, 2006 | 10:34 AM
Update, I added somethings
I will add the tools I use to troubleshoot. Some of them are not chepa, but when you need them, they are priceless.
Old Apr 30, 2006 | 01:53 PM
jdm*'s Avatar
Old Jun 20, 2006 | 10:51 PM
itr1244's Avatar
Default Re: FAQ: Common swap problem AND general troubleshooting! (jdm*)
best write up ever
Old Sep 10, 2006 | 02:39 PM
. M i c h a e l's Avatar
dotmichael to you
very, very cool. much thanks to you for taking on this task.
Old Sep 11, 2006 | 10:07 AM
amy's Avatar
amy
Default Re: FAQ: Common swap problem AND general troubleshooting! (. M i c h a e l)
SIR HOW MANYWASHERS GO ON A BOLT ?
lol
i suck
Old Sep 11, 2006 | 06:35 PM
RotiEatter's Avatar
Ditto
Why is this not a sticky yet? Does Hybrid even have a mod? haha
Old Sep 11, 2006 | 06:56 PM
JayWest's Avatar
Kenny for President!!!
Old Sep 13, 2006 | 06:41 AM
Smokeeey420's Avatar
hey man my pm's won't work
can u email me about some tunning i need ??
i'm in west palm beach r u good with emange?? i got emange blue w/ profec e-01 thanks xxsmokeeeyxx420@aol.com
Old Sep 13, 2006 | 06:25 PM
project_hatch1.8's Avatar
Default Re: (Smokeeey420)
I thought part B was gonna be spark. I only ask cuz I' have no spark right now and its very frustrating! Anyways good write up man
Old Sep 18, 2006 | 09:08 PM
vtecn8ive's Avatar
Default Re: (project_hatch1.8)
awesome write up man.
Old Sep 21, 2006 | 03:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">very, very cool. much thanks to you for taking on this task.</TD></TR></TABLE>
Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy &raquo;</TD></TR><TR><TD CLASS="quote">SIR HOW MANYWASHERS GO ON A BOLT ?
lol
i suck</TD></TR></TABLE>
Too many
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">Why is this not a sticky yet? Does Hybrid even have a mod? haha</TD></TR></TABLE>
I think Poison should be a mod. No one mods this forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaywest10 &raquo;</TD></TR><TR><TD CLASS="quote">Kenny for President!!! </TD></TR></TABLE>
haha, nah, Mat for president!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project_hatch1.8 &raquo;</TD></TR><TR><TD CLASS="quote">I thought part B was gonna be spark. I only ask cuz I' have no spark right now and its very frustrating! Anyways good write up man </TD></TR></TABLE>
I have read that thing like 20 times and never saw that, I will get on it. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">awesome write up man.</TD></TR></TABLE>
Thanks for everyones kind words
