Axle Issues
Old Jan 10, 2006 | 02:45 PM
O RLY's Avatar
Default Axle Issues
Okay, I'm about to show you some photos of a disaster I have created. I want to replace my driver side axle in my H22 EJ. Here's a photo of the 90-93 Integra axle:
Now, as you can see in this next photo, my intermediate shaft is not compatible. There's the CV from the old axle. I think we swapped it last time to make it work. Is it an Accord i-shaft, or a Prelude i-shaft?
I may just have to swap the ends to make it work, but want to know if maybe I can buy a different i-shaft. Here's another picture, kind of useless.
I'm basically just getting tired of swapping the CVs every time I change an axle, and want something that will just simply fit. Thanks for your help, Rob.
Old Jan 10, 2006 | 03:05 PM
skunked's Avatar
Default Re: Axle Issues (O RLY)
I had a prelude midshaft and had to use a prelude inner as well with the 86-89 teg axle.
Old Jan 10, 2006 | 04:08 PM
jdmcars.com's Avatar
The 90-93 would be used only for the length (or maybe the 89 integra axle might be best) -You still have to build it using the Prelude inner hub.
This all depends on the mount kit that you are using, what combination of axle to use.
From your frustation, it seems like you might have been through this before? If you have been having axles troubles, might be time to step up and buy some stronger axles built for your swap.
Old Jan 10, 2006 | 06:11 PM
Goinfasterthanu's Avatar
If you get the accord half shaft you can use 90-93 teg axle ....Itll fit right on ...No building an axle..
Old Jan 10, 2006 | 07:49 PM
RotiEatter's Avatar
Ditto
Why not just purchase a set of stage 1 axles?
Old Jan 11, 2006 | 07:31 AM
Adam West's Avatar
Default Re:
QUOTE=O RLY]Okay, I'm about to show you some photos of a disaster I have created. I want to replace my driver side axle in my H22 EJ. Here's a photo of the 90-93 Integra axle:
I'm basically just getting tired of swapping the CVs every time I change an axle, and want something that will just simply fit. Thanks for your help, Rob. [/QUOTE]
I just bought a set of axles with only the outer pieces that connect to the wheel hub.. what should I do to them to get them to work????? buy prelude inners or accord inners????????? HELPPPPPP
Old Jan 11, 2006 | 08:39 AM
O RLY's Avatar
Default Re: Re: (Oclooc)
I'm not sure that either will work. You basically hafta swap the CVs from on axle to the next. I'm not sure which CVs you swap, that's why I created this thread. People always say use a 90 Accord halfshaft with 90-93 integra axles, but does it hookup w/o having to swap CVs?
Old Jan 11, 2006 | 09:34 AM
Adam West's Avatar
Default Re: Re: (O RLY)
ok I am missing the round piece on the left side of the first pick.. mine only has the right side and the shaft!!!!!! what do I do????????
Old Jan 11, 2006 | 01:07 PM
93accordNOS's Avatar
You have a prelude intermediate shaft in your picture. If you swap to an accord intermediate shaft I believe the 90 teg axle is plug and play.
Old Jan 11, 2006 | 01:31 PM
Braco11's Avatar
Default Re: (93accordNOS)
^^^^yup, looks to me to be a prelude i-shaft. I think I have an extra accord i-shaft in my garage. PM me if you want it.
Conner
Apr 7, 2018 08:38 PM
2sLoJR
Mar 20, 2014 10:39 AM
integrainside
Transmission & Drivetrain
Oct 3, 2013 05:21 PM
HTtuner
Jun 26, 2010 07:04 PM
jpnucrx
16
Nov 8, 2006 07:35 AM
